Hi Guys
I’m trying to write a smartapp that sends me a message on certain events
These events are from a water sensor which I’m using to interface with my wired home alarm
(I have them setup to trigger an event when the alarm zone becomes active)
BUT…Only if a virtual switch is on - If the switch is off then I don’t want the messages
The events part of the app works perfectly - I get the required sms or push message every time
What I’m having problems with is the disabling of the messages when the virtual switch is off
This is what I have so far…
Here is my switch selection
section("Select switch to control messages"){
paragraph "Select the switch to turn on/off (Used to enable/disable messages)"
input "switch1", "capability.switch", title: "Notification on/off", required: true, multiple: false
Here is my subscription for the switch
subscribe(switch1, "switch.on", onHandler1)
subscribe(switch1, "switch.off", offHandler1)
Here are my event handlers for the switch
def onHandler1(evt) {
log.debug "$switch1 is switched On - Enabling notifications"
def CurrS1 = switch1.currentSwitch
log.debug “$switch1 is $CurrS1”
def offHandler1(evt) {
log.debug "$switch1 is switched off - Disabling notifications"
Here is one of my event handlers for the main events
def dryHandler1(evt) {
if ($CurrS1 == “on”) {
log.debug “$water1 shows dry - $switch1 enabled - sending message to user(s)”
if ($phone1 != 'null'){
sendSms(phone1, "$dryText1")}
else if ($phone2 != 'null'){
sendSms(phone2, "$dryText1")}
else if ($phone3 != 'null'){
sendSms(phone3, "$dryText1")}
else if ($phone4 != 'null'){
sendSms(phone4, "$dryText1")}
else {
sendPush("$dryText1")
else log.debug “$water1 shows dry but the $switch1 is disabled so I’m not sending any message”
I need to be able to disable the messages when the alarm is not set (I have a connection in the panel to control this)
Where am I going wrong??
(Be gentle this is my 1st app!)
Andy
