rontalley
(Ron Talley)
June 23, 2017, 12:33pm
8
It’s great having a little Pi to serve other things that connect to SmartThings. The sync is easily fixed with Host Pinger which my Pi host. I even use the PC as a motion sensor! It is explained in my tutorial:
How about:
Turn on Kitchen PC
Turn off Bedroom PC
Mouse is Active
Turn on Kodi
Even Works with Alexa or Hey Google!!
This Tutorial will not only show you how to make your PC a totally controllable Switch in ST, but also use Virtual Switches as a Motion device or to Execute Programs which can all be used for Home Automation! After setup, your PC status will be in perfect sync with the Virtual Switch no matter if you turn on/off the PC manually or through SmartThings.
It might seem like a lot but you can have this up and running fairly quickly especially if you are already familiar with installing custom apps. It’s up to you how far you want to go down the rabbit hole!
Tools used: Send Events to Event Ghost (App), Host Pinger (App), EventGhost (Free Windows Program), CoRE or webCoRE …
