After looking at the coding already done for Message Central, I have decided it needs a re code and a full cleanup.
This thread is for the new version: Message Central 10
I’ll fill in the sections as I do them.
Proposed Triggers:
Button - Pushed/Held
Switch - On/Off
Contact - Open/Close
Contact - Left open too long
Presence - Arrival/Departure
Water - Wet/Dry
Time - Schedule a reminder at configured time
Time - if contact open (Check at a certain time if something is open.)
Power - Alert when power goes below or above a threshold
(And optionally ‘stays that way’ for a configurable amount of time - perfect for laundry appliances that drop
below the threshold a couple of times before finally staying there when finished) -
Motion - on ‘active’ or on 'inactive’
Temperature - either above or below a set point.
Mode change
Routine run
Appliance Power Monitor - This works the same as the power monitoring except that the power drawn MUST go above a threshold before monitoring starts
Proposed Actions:
‘Speak’ a message using a Sonos speaker or equivalent
Push/SMS a message
Proposed Restrictions:
Mode
Presence
Time
Days of the week
Sunset & Sunrise (with offset)
Proposed Additional Options:
Variables to add detail to messages:
%time% - Replaced with current time in 12 or 24 hour format (Switchable)
%day% - Replaced with current day of the week
%date% - Replaced with current day number & month
%year% - Replaced with the current year
%weather% - Replaced with the current weather forecast
%opencontact% - Replaced with a list of configured contacts if they are open -
Speaker volume - set ‘quiet time’ with different volume
Delay before speaking/sending message
Repeat Message/Single message - with a configurable number of repeats and delay between messages.
Missed messages - Separate ‘child’ app - where timed messages are configured but you were not at home to receive them, then list missed messages when you return
‘Follow Me’ speakers to use motion sensors to only play messages where there are people (with a ‘default’ if there is no movement anywhere)
