Sorry to ask such a basic question. I just purchased a new 2018 v3 Smartthings hub. I can’t add as device.
Smartthings app on iPhone, signed in
Smartthings hub connected via Ethernet. Checked my Internet access is great. I have Orbi router, make sure any port blocking is off and device access control is off. Smarthings hub shows as connected device on Orbi via Ethernet and I can ping the hub from my iMac
When I try to add the hub as new device always get “hub can’t be found”
I did the factory reset - hold pin until blinking yellow goes solid
I did the reset again on the hub - blinking yellow, until solid, remove pin…
Then tried to add hub via WiFi - no luck, then tried to add via Ethernet - no luck
I logout, delete the app. Re-downloaded the app fresh, then re-login and still no luck
I swapped out the Ethernet cable. Can see the Smartthings hub has IP address via the router’s web I/F admin. screen. I can also can ping the hub from my iMac, so appears the hub has connection. I will try rebooting the router (after my wife stops using the Internet).
Also the hub name that is listed on the router attached device page does match the serial number label on the hub itself, so doesn’t seem like a bad S/N label.
I guess should check to see if any know issues with Orbi routers and Smarthings hubs? Their is no port blocking set on the router so doesn’t seem like any block messages from the hub would be fault.
