You can install the app manually this way.
Start by going to the SmartThings developer tools page at https://graph.api.smartthings.com. Login to the developer tools, creating an account if needed.
Then copy all of the code from GitHub here: https://github.com/jkohlen/Smart-Weather-Lamp/blob/master/Smart-Weather-Lamp.groovy or from the code pasted below. On the developer tools page, click “My SmartApps” and then “New SmartApp”. Select the tab “From Code” and paste the copied code into the box. Click the “Create” button at the bottom of the page. Finally click “Publish” -> “For Me” to publish this app to your account.
Then open your SmartThings mobile app, click the big plus sign at the bottom of the dashboard, Scroll across the top of the screen as far as you can. The last entry on the right should be “My Apps.” You’re self published apps should be there – including the Color Changing Smart Weather Light. Select it to install, choose a motion sensor, a color changing light (like a Phillips Hue Bulb or LifX), enter your zipcode, select an icon for the app and press “done.” You should be enjoying better weather in no time!
Alternatively, copy the code from here:
* Color Changing Smart Weather lamp
* This weather lantern app turns on with motion and turns a Phillips hue (or LifX) lamp different colors based on the weather.
* It uses dark sky's weather API to micro-target weather.
* Weather Lamp Colors
* Blinking Red Weather Watch, Warning or Advisory for your location
* Purple Rain: It’s raining outside. Triggers when there is greater than 15% chance of rain in this or the next hour
* Blue Cold: It’s freezing outside
* Pink Snow: There is a chance of snow
* Orange Hot: It’s hot outside -- above 90F
* Green Sneeze: Pollen is in the air - above 7 (polin requires integration with IFTTT that sets a virtual switch in ST
* White All clear
* With special thanks to insights from the Flasher script by Bob, the SmartThings Hue mood lighting script, the light on motion script by kennyyork@centralite.com, and the Smartthings severe weather alert script
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Color Changing Smart Weather Light",
namespace: "",
author: "Jim Kohlenberger",
description: "A color changing smart weather lantern app that turns on with motion and turns a hue lamp different colors based on the weather.",
category: "",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Developers/smart-light-timer.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Developers/smart-light-timer@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Developers/smart-light-timer@2x.png")
preferences
section("Select Motion Detector") {
input "motion_detector", "capability.motionSensor", title: "Where?"
section("Control these bulbs...") {
input "hues", "capability.colorControl", title: "Which Hue Bulbs?", required:true, multiple:true
section("Set brightness level for lights (100 is max representing 100%, default is 60)") {
input "brightnessLevel", "number", title: "Brightess level (without %)?", required: false
section ("Zip code (optional, defaults to location coordinates)...") {
input "zipcode", "text", title: "Zip Code", required: false
section ("In addition to push notifications, for emergency weather send text alerts to...") {
input "phone1", "phone", title: "Phone Number 1", required: false
input "phone2", "phone", title: "Phone Number 2", required: false
input "phone3", "phone", title: "Phone Number 3", required: false
section ("Optionally set lantern to turn green once, if this switch is turned on.") {
input "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: false
section("Icon") {
icon(title: "Select icon for app:", required: true)
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
scheduleJob()
def updated() {
log.debug "Updated with settings: ${settings}"
log.debug "Weather Light: oldKeys: $oldKeys"
unsubscribe()
unschedule()
scheduleJob()
initialize()
def scheduleJob() {
def sec = Math.round(Math.floor(Math.random() * 60))
def min = 4
def cron = "$sec $min * * * ?"
schedule(cron, "turnOff")
def checkForWeather() {
def alerts
def conditions
def color ="Warm White"
def statustest
def value
if(locationIsDefined()) {
if(zipcodeIsValid()) {
alerts = getWeatherFeature("alerts", zipcode)?.alerts
conditions = getWeatherFeature("conditions", zipcode )
} else {
log.warn "Severe Weather Alert: Invalid zipcode entered, defaulting to location's zipcode"
alerts = getWeatherFeature("alerts")?.alerts
conditions = getWeatherFeature("conditions") }
} else {
log.warn "Severe Weather Alert: Location is not defined"
log.debug "Weather conditions temp_f: ${conditions.current_observation.temp_f.toInteger()}"
// FREEZING BLUE
if (conditions.current_observation.temp_f <= 34 ) {
color = "Blue"
log.debug "Weather temp below 34F, its freezing out so setting light to blue."
// HOT ORANGE
if (conditions.current_observation.temp_f >= 80 ) {
color = "Orange"
log.debug "Weather temp above 80F, setting light to orange."
// PURPLE RAIN FORCAST
log.debug "Checking Forecast.io Weather"
httpGet("https://api.forecast.io/forecast/8b533da63e8dc7e74a1aa20acaf8ac13/$location.latitude,$location.longitude") {response ->
if (response.data) {
def precipprob = response.data.currently.precipProbability.floatValue() // A numerical value between 0 and 1 (inclusive) representing the probability of precipitation occurring at the given time.
def tempFar = response.data.currently.temperature.floatValue()
def thisHour = response.data.minutely.data[0].precipProbability.floatValue() //this top of hour
def nextHour = response.data.minutely.data[1].precipProbability.floatValue() //next top of hour
log.debug "Actual current temp: ${tempFar}, Precipitation probability now: ${precipprob}, thisHour: ${thisHour}, nextHour ${nextHour}"
if ((thisHour >15) || (nextHour >15)) {
color = "Purple"
log.debug "Greater than 15% chance of rain in this or the next hour, setting light to Purple."
} else {
log.debug "HttpGet Response data unsuccesful."
// PINK SNOW
def f = getWeatherFeature("forecast", zipcode) //get("forecast")
def f1= f?.forecast?.simpleforecast?.forecastday
if (f1) {
value = f1[0].snow_day
else {
log.warn "Forecast not found"
log.debug "The chance of snow = ${value}"
if (!value.toString().contains("0.0")) {
if (!value.toString().contains("null")) {
color = "Pink"
log.debug "Weather shows chance of snow, setting light to Pink."
sendcolor(color)
def newKeys = alerts?.collect{it.type + it.date_epoch} ?: []
log.debug "Severe Weather Alert: newKeys: $newKeys"
def oldKeys = state.alertKeys ?: []
log.debug "Severe Weather Alert: oldKeys: $oldKeys"
if (newKeys != oldKeys) {
state.alertKeys = newKeys
alerts.each {alert ->
if (!oldKeys.contains(alert.type + alert.date_epoch) && descriptionFilter(alert.description)) {
color = "Red"
sendcolor(color)
flashLights()
def descriptionFilter(String description) {
def filterList = ["special", "statement", "test"]
def passesFilter = true
filterList.each() { word ->
if(description.toLowerCase().contains(word)) { passesFilter = false }
passesFilter
def locationIsDefined() {
zipcodeIsValid() || location.zipCode || ( location.latitude && location.longitude )
def zipcodeIsValid() {
zipcode && zipcode.isNumber() && zipcode.size() == 5
private send(message) {
sendPush message
if (settings.phone1) {
sendSms phone1, message
if (settings.phone2) {
sendSms phone2, message
if (settings.phone3) {
sendSms phone3, message
def sendcolor(color) {
log.debug "Sendcolor = $color"
def hueColor = 0
def saturation = 100
switch(color) {
case "White":
hueColor = 52
saturation = 19
break;
case "Daylight":
hueColor = 53
saturation = 91
break;
case "Soft White":
hueColor = 23
saturation = 56
break;
case "Warm White":
hueColor = 20
saturation = 80 //83
break;
case "Blue":
hueColor = 70
break;
case "Green":
hueColor = 39
break;
case "Yellow":
hueColor = 25
break;
case "Orange":
hueColor = 10
break;
case "Purple":
hueColor = 75
break;
case "Pink":
hueColor = 83
break;
case "Red":
hueColor = 100
break;
state.previous = [:]
hues.each {
state.previous[it.id] = [
"switch": it.currentValue("switch"),
"level" : it.currentValue("level"),
"hue": it.currentValue("hue"),
"saturation": it.currentValue("saturation")
log.debug "current values = $state.previous"
// CHECK for GREEN button on
if (mySwitch != null) {
if (mySwitch.latestValue("switch") == "on" ) {
log.debug "mySwitch is on so setting light to GREEN and closing switch"
if (color != "Red") { //If its red, then override green
hueColor = 39
mySwitch.off()
def lightLevel = 60
if (brightnessLevel != null) {
lightLevel = brightnessLevel
def newValue = [hue: hueColor, saturation: saturation, level: lightLevel]
log.debug "new value = $newValue"
hues*.setColor(newValue)
/// HANDLE MOTION
def turnOff() {
log.debug "Timer fired, turning off light(s)"
hues.off()
def motionHandler(evt) {
if (evt.value == "active") { // If there is movement then...
log.debug "Motion detected, turning on light and killing timer"
checkForWeather()
unschedule( turnOff ) // ...we don't need to turn it off.
else { // If there is no movement then...
def delay = 100
log.debug "Motion cleared, turning off switches in (${delay})."
pause(delay)
hues.off()
def initialize() {
log.info "Initializing, subscribing to motion event at ${motionHandler} on ${motion_detector}"
subscribe(motion_detector, "motion", motionHandler)
subscribe(app, appTouchHandler)
def appTouchHandler(evt) {
checkForWeather()
def delay = 4000
log.debug "App triggered with button press, turning off switches in (${delay})."
pause(delay)
hues.off()
private flashLights() {
def doFlash = true
def onFor = onFor ?: 1000
def offFor = offFor ?: 1000
def numFlashes = numFlashes ?: 3
log.debug "LAST ACTIVATED IS: ${state.lastActivated}"
if (state.lastActivated) {
def elapsed = now() - state.lastActivated
def sequenceTime = (numFlashes + 1) * (onFor + offFor)
doFlash = elapsed > sequenceTime
log.debug "DO FLASH: $doFlash, ELAPSED: $elapsed, LAST ACTIVATED: ${state.lastActivated}"
if (doFlash) {
log.debug "FLASHING $numFlashes times"
state.lastActivated = now()
log.debug "LAST ACTIVATED SET TO: ${state.lastActivated}"
def initialActionOn = switches.collect{it.currentSwitch != "on"}
def delay = 1L
numFlashes.times {
log.trace "Switch on after $delay msec"
hues.eachWithIndex {s, i ->
if (initialActionOn[i]) {
s.on(delay: delay)
else {
s.off(delay:delay)
delay += onFor
log.trace "Switch off after $delay msec"
s.off(delay: delay)
else {
s.on(delay:delay)
delay += offFor
//delay += offFor
//s.off(delay:delay)
