Hub located in Romania, initiated migration in Canada. App showing 2 locations RO and CA. Devices migrated to CA location and automations to RO location. How can I merge under RO location?
Unfortunately there’s no way for you to do it, it needs to be done by SmartThings support. Personally, I do not recommend using the migrate button as it often creates more issues than it solves.
All the button is supposed to do is to convert your Routines into Automations and Scenes and uninstall the guest lock and SHM apps. You can do these yourselves as explained here:
It’s better if you do this yourself instead of using the migrate button. Everything else should just show up in the new app.
100% THIS ^^^^^^^^
They absolutely killed my automations!!
