ChrisB’s “Hallway Light at Night” - more than one motion sensor?
Hi there,
Using Chrisb’s “hallway light at night” as a nightlight and it works great, however, it can only select 1 motion sensor for each dimmer.
Can someone help me change the code so that I can select multiple motion sensors per dimmer (like the stock smartthings apps)?
 *  Hallway light at night.
 *  Author: chrisb
 *  Borrowing pieces of code by: SmartThings & CoryS from "Lights Follow Me Dimmable"
 *  Turn a dimmer light on at a low level if it isnt on already for a few minutes
 *  when motion is detected during a given time period.
 *  Example use would to be turn on a hall light at a low percentage at time when
 *  someone gets up to use the bathroom at night.
// Automatically generated. Make future change here.
definition(
    namespace: "",
    author: "seateabee@gmail.com",
    description: "Turn a dimmer light on at a low level if it isnt on already for a few minutes when motion is detected during a given time period. Example use would to be turn on a hall light at a low percentage at time when someone gets up to use the bathroom at night.",
    category: "My Apps",
    iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
    iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png",
    oauth: true
preferences {
	section("Turn on when there's movement..."){
		input "motion1", "capability.motionSensor", title: "Where?"
	section("And off when there's been no movement for..."){
		input "minutes1", "number", title: "Minutes?"
	section("Turn on this dimmer switch...") {
    	input "MultilevelSwitch", "capability.switchLevel", title: "Which?"
    section("How Bright?"){
    	input "number", "number", title: "Percentage, 0-99"
	section("Only dim between this time at night:") {
		input "timeOfDay1", "time", title: "Start Time?"
    section("and this time in the morning:") {
		input "timeOfDay2", "time", title: "End Time?"
def installed()
	subscribe(motion1, "motion", motionHandler)
	subscribe(MultilevelSwitch, "switch.on", switchOn)
    subscribe(MultilevelSwitch, "switch.off", switchOff)
def updated()
	unsubscribe()
def motionHandler(evt) {
	log.debug "$evt.name: $evt.value"
    if (evt.value == "active") {  									// We're seeing motion, so go to next test...
    	MultilevelSwitch.refresh()
		log.debug "Seeing motion..."
        def startTime = timeToday(timeOfDay1)
    	def endTime = timeToday(timeOfDay2)
		if (now() < startTime.time && now() > endTime.time) { 			// Testing time of day.  If the statement is true, we're outside our
    		log.debug "Outside of time range, doing nothing."			// time frame, so we're doing nothing.
	    else {															// Passed time test, so go to next test...
        	log.trace "We're inside the time range."
	     	if (state.switch == 0) {										// Passed last test, light is off.  Let's go dimming!
				log.debug "Light is off, let's go dimming!"
        		unschedule(reset)													//Turn off any scheduled resets.
                settings.MultilevelSwitch.setLevel(number)
				def timeDelay = minutes1 * 60										//runIn uses seconds. Multiply by 60 to convert to seconds.
            	runIn (timeDelay, reset)
            else {
            	log.debug "Light is on... I'm not touching it."
            }																// Completes the "if the light is on" test.
        }  																// Completes the "if it's the right time" test.
	}																// Completes the "there's motion" test.
def switchOn(evt) {
	log.debug "Switch on, state = 1"
    state.switch = 1				// When switch is on we're not going to run the dimmer function.  1 = on
def switchOff(evt) {
	log.debug "Switch off, state = 0"
	state.switch = 0				// When switch is off, we'll run the dimmer function.  0 = off
def reset() {						// The dimming event will leave the light level very low, so reset to full level
	settings.MultilevelSwitch.setLevel(99)
    MultilevelSwitch.off()
If you simply want to select multiple motion sensors to trigger the same light, change
to
input "motion1", "capability.motionSensor", title: "Where?",multiple: true
@kevintierney - that did it. Thanks!!
