I’m not really a programmer, so forgive me if these questions seem simple, but I couldn’t figure them out.
I would like to change the “Notify Me When” app so that it will tell me which of my multis caused the alert.
I thought I did it by changing the sendPush to sendPush(evt.name + evt.value), but evt.name calls every multi “contact” instead of the actual name. Contact.name doesn’t work either.
I also couldn’t figure out how to put a space in between the 2…+ " " + didn’t work
Lastly (for now), is there a way to rename the virtual contact? I thought it was working because the virtual contact was called contact, but then realized it wasn’t when they all showed up that way.
Thanks. Hopefully that will work - though it took me some time to realize that when I copied and pasted, the quotes pasted as curly quotes and were causing an error.
Unfortunately (for this purpose), I am using SmartThings at a second home so I now just have to wait until one of the doors opens. Luckily, someone is supposed to do some work in the house today and will be opening/closing the doors.
As I said, I have very little programming experience, but how would one know that linkText is a valid input? I don’t see any examples of it in the documentation and don’t see any library of the potential choices.
