Hi all,
I am trying to mod the switch changes mode app so when you turn the switch off it reverts to the previous mode.
I defined my variable and it sets the current mode to lastMode, but when the switch is turned off it lastMode is set to null. How do I keep lastMode set between app calls?
* Switch Changes Mode
* Copyright 2015 Michael Struck
* Version 1.01 3/8/15
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Ties a mode to a switch's (virtual or real) on/off state. Perfect for use with IFTTT.
* Simple define a switch to be used, then tie the on/off state of the switch to a specific mode.
* Connect the switch to an IFTTT action, and the mode will fire with the switch state change.
definition(
name: "Switch Changes Mode",
namespace: "MichaelStruck",
author: "Michael Struck",
description: "Ties a mode to a switch's state. Perfect for use with IFTTT.",
category: "Convenience",
iconUrl: "https://raw.githubusercontent.com/MichaelStruck/SmartThings/master/IFTTT-SmartApps/App1.png",
iconX2Url: "https://raw.githubusercontent.com/MichaelStruck/SmartThings/master/IFTTT-SmartApps/App1@2x.png",
iconX3Url: "https://raw.githubusercontent.com/MichaelStruck/SmartThings/master/IFTTT-SmartApps/App1@2x.png")
preferences {
//page(name: "getPref", title: "Choose Switch and Modes", install:true, uninstall: true) {
section("Choose a switch to use...") {
input "controlSwitch", "capability.switch", title: "Switch", multiple: false, required: true
section("Change to a new mode when...") {
input "onMode", "mode", title: "Switch is on", required: false
input "offMode", "mode", title: "Switch is off", required: false
def installed() {
log.debug "Installed with settings: ${settings}"
subscribe(controlSwitch, "switch", "switchHandler")
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
def switchHandler(evt) {
if (evt.value == "on") {
def lastMode = location.mode
log.debug "(ON) mode is ${lastMode}"
changeMode(onMode)
} else {
log.debug "(OFF) mode is ${lastMode}"
if (lastMode && !offMode) {
offMode = lastMode
changeMode(offMode)
def changeMode(newMode) {
if (newMode && location.mode != newMode) {
if (location.modes?.find{it.name == newMode}) {
setLocationMode(newMode)
log.debug "Changed mode to '${newMode}'"
else {
log.debug "Unable to change to undefined mode '${newMode}'"
