I am using a contact sensor on a well float such that when it’s not “contacted”, it means I have a leak in the area. The contact sensor uses the standard Edge driver for a contact, but that prevents it from being used as a leak (leak monitor in STHM). With DTHs, I simply switched it to the closest Groovy leak sensor and it worked great. With Edge, I try to change the driver but it won’t let me select any of the leak sensor Edge drivers I have installed on the hub. Is there any way to do this without creating a custom Edge driver?
You didn’t give the brand and model of the sensor you want to change. If it happens to be zwave, there is a zwave edge driver that will let one type of simple sensor pretend to be a different type. (The topic title is a clickable link.)
You have to subscribe to that channel, download the masquerade Driver, and then switch to it.
I don’t think there’s anything similar for Zigbee devices. One workaround would be to create a virtual sensor of the type you do want that also has a switch capability, then use routines to turn the virtual sensor on and off as the real sensor’s state changes.
