Hello. I would like to connect my Chamberlain MyQ Opener to SmartThings. Is there a way this can be done. I essentially would like to create a rule where the opener would open the door and turn on the exterior lights when I come home.
jkp
August 16, 2017, 5:52pm
2
These post should get you started…
This SmartApp integrates Chamberlain/LiftMaster MyQ doors and light controls into SmartThings. It creates a garage door or light switch (MyQ light module, not the light on the door itself) device in your list of Things and allows you to control the device…
By tapping the device buttons in the SmartThings mobile app
Automatically by your presence (coming or going) in a Routine or other SmartThings rules app
Via switch tiles in a SmartTiles dashboard
By asking Alexa or Google Home to turn the on the door or light
[image] [image]
Installation and Usage
Follow the instructions and get the code here: GitHub - brbeaird/SmartThings_MyQ: Integrate SmartThings with MyQ (Obsolete) . Make sure and install the SmartApp code as well as the applicable device handlers
An optional (but strongly re…
CoRE (now WebCore) is a very powerful community – created rules engine for SmartThings. It allows you to set up stacked conditionals like “If A then B but only while C and not if D.”
Setting it up can be quite complex, but there are many community members who will be glad to help you.
For example, here is a piston that one member created to notify him if the dog had already been fed twice that day and he picked up the dog bowl for a third time. He needed this because he has a large family and people didn’t always remember whose turn it was to feed the dog.
[image]
The original version of CoRE Has now been replaced by a new version, WebCoRE, which moves the data entry to a web interface. This allows for flexibility and an architecture that requires more memory than is av…
