Challenges with BTF Lighting Zigbee 5-in-1 LED Strip Controller
Hello - I’ve got a FCOB CCT LED strip that I’m trying to control with a BTF Lighting Zigbee 5-in-1 LED Strip Controller (Model: LM052). Link to the product on Amazon at the bottom.
There are 5 modes that you toggle through to get the correct setting:
W
WW CW
RGB
RGBW
RGB WW CW
Unfortunately, when you turn on power to the controller, it defaults to the 1st setting and one has to use the “SET” button to manually cycle through the modes. It does not seem to remember the setting if the power is recycled. This makes it very problematic for automation.
Does anyone know a way around this? I’m just using the standard generic Zigbee driver that the controller picked up when I added it as a new device to Smartthings.
Any pointers would be greatly appreciated.
https://www.amazon.com/BTF-LIGHTING-Controller-Support-Compatible-Home-kit/dp/B0BPBPGJ5G
