Wait are we having the same problem, when you try to add a new pin with action in 3400-XKeypad Manager it fails on Android but works fine on iOS. That doesn’t create a log entry when it fails (at least on my end).
However the actual keypad works fine at executing routines once I install the smartapp via iOS.
Here are the errors I just received when trying to add
15d1473b-a2c4-45e1-9caa-7aec6f854a87 9:38:46 AM: error groovy.lang.MissingMethodException: No signature of method: java.lang.String.setDisarmed() is applicable for argument types: () values: [] @ line 83
15d1473b-a2c4-45e1-9caa-7aec6f854a87 9:38:46 AM: debug Keypad manager caught alarm status change: off
15d1473b-a2c4-45e1-9caa-7aec6f854a87 9:38:46 AM: debug Installed with settings: [stayRoutine:Good Night!, keypad:e7c68a2f-dc8f-48a0-9d59-f036a4d4481b, disarmRoutine:I’m Back!, pin:6116, armRoutine:Goodbye
This is everything i get
854ec14f-e9e8-4f9a-abfa-704a0e72bad6 11:15:21 AM: debug event from: Living Room Motion, value: active, source: DEVICE, description: zone status 0x0022 – extended status 0x00
3a92e9f6-84a1-4af0-85d5-a740cf27af2d 11:14:47 AM: error groovy.lang.MissingMethodException: No signature of method: java.lang.String.setDisarmed() is applicable for argument types: () values: [] @ line 83
3a92e9f6-84a1-4af0-85d5-a740cf27af2d 11:14:47 AM: debug Keypad manager caught alarm status change: off
I can’t see anything wrong at all, will have to trace it over weekend…
If you are really interested, you could post a log for a successful status change (Armed away, then disarmed). I’d be curious if all the status changes are erroring…
I think this error is different from the Android error.
Ahh, double confused. It is android, but it’s at a different spot. I will be checking it out, as I have one of these in a box ready to play with. Thanks for the debug, I have ideas to check, thanks!
I am looking to add a keypad to set up the appropriate SHM Modes upon enter/exit of the home. I skimmed through the thread but have the following questions:
Can this keypad be used to set SHM Modes and to also set up a security code for entry? Can this be used like a traditional security alarm to set the appropriate mode upon entry / exit?
I’m getting this when I try to access the devicetype from the smartapp: groovy.lang.MissingPropertyException: No such property: supportedCommands for class: java.lang.String @ line 107
keypad is the input to the smartapp. This has got to be some dumb thing about groovy I don’t know yet, I’m a java hack (barely). Pick this back up tomorrow, but wouldn’t mind some public shaming about why I can’t do this in the smartapp:
Definitely didn’t paste one into the other, I’m thankfully long past making that error.
This is deeper. And yes, I’m using a custom app and device type. I’m troubleshooting the install problems with the Smartapp. It has something to do with calling this devices commands from the Smartapp.
If this is the problem where it doesn’t install from android but it does stall from iOS, isn’t that just an issue with the install? That there some corruption problem in the initial publish?
I don’t actually see how this could only be Android, and it would be helpful for someone in iOS land to confirm that they have successfully installed the recent version of the SmartApp specifically.
The devicetype works fine for me (Android), but the Smartapp errors on install. It is not related to the Android app errors that I’m familiar with, it’s something else.
Maybe my experience with this issue will help. This is currently an issue with Android installs only. Multiple users have confirmed that they can install the SmartApp successfully using an iOS device, even some users who’s install failed initially using Android.
The root of the issue is that the Android App is not pulling the Device Type and Device Name correctly when assigning a keypad to be used in the SmartApp. Where it should be pulling a Device Type of ‘device.centraliteKeypad’ it’s pulling one just named ‘device’. Where is should be pulling the actual name of the device it’s pulling the device ID (used in the Device page URL). See below:
What it should be:
Name Type Value
keypad device.centraliteKeypad Centralite Keypad
What it is:
Name Type Value
keypad device 46931c78-9bce-4b13-8416-c355c1d39346
ST is aware of this issue and have acknowledged that it’s on their side and that it’s being worked on but they have no timeline on a fix.
