I’m not sure if there is something going on again with GitHub integration or not. I just updated two DTH’s in my GitHub. I do a update from repo, select them, and execute update with this error:
Updated 0 devices and created 0 new devices, 0 published (2 skipped due to errors)
Usually this means there is something wrong with the code. So I go to GitHub, view as raw, select all, copy, and paste it as New Device -> From Code. DTH installs fine. Assign it to a device. Device works fine, no errors in logging (which is also a bit buggy right now…). Is there anywhere to go to look and see why there were errors? I already checked the basics…no other devices with the same name, meta data definition is good. Also tried doing them one by one with same skipped result. I went back and tried a different DTH, a old one, and that one installed correctly so that tells me there is something with these two newly updated ones but I would think they wouldn’t install locally if that were the case.
