Can't build an automation to change security mode
Correct, 2 locations. Maybe better to show the lineup this way:
CABIN location - CAN manage STHM with automation
  • has 2 scenes
  • has STHM installed
HOME location CAN’T manage STHM with automation
  • Has no scenes
  • Has STHM installed (Also just reinstalled today as test)
Both hubs are on same FW version 37.00004
OK, NOw I’m really stumped. I looked again tonight and all of a sudden, STHM and scenes are available when I setup a new automation. I have no idea why. Maybe ST people lurk here and someone gave my system a bump. If I do have a ST guardian angel, thanks!!
I am having the exact same problem with STHM- I get the ‘greyed out’ “Change Security Mode”. Any theories, besides the angel, that made it come alive? Thanks!
Robert,
I have no idea what caused it to all of a sudden start working. I have an iPhone and 2 iPads. I looked on all 3 of them and saw the same greyed out STHM and Scenes. One thing I did find that one of the iPads still had the old app installed with the new one. I uninstalled the old app. It was a few hours until it started working. I’m not saying there is a connection but I am curious. Do you happen to have any devices with the old app?
Thanks! I figured it out last night. I needed to establish a ‘Scene’ first. So I made one that does nothing…and suddenly I can change the security mode in “Then”. Three hours of my life picking through, re-installing, redoing my system and it came down to that simple thing. :grinning:
Very interesting, I think I may have done the same thing. I didn’t think much of it at the time. I created the scene and when I couldn’t think what I wanted to do with it, I just left the empty scene and moved on. Quite possibly that was what was needed.
Hopefully this helps anyone else looking!
That is very strange. To clarify, did you have to add the scene to the automation or just had to have a scene created in general?
I just needed to make a scene.
But it wasn’t in an automation or in public :rofl: :joy:
THANK YOU PhiL! I have spent many hours trying different things, searching automation solutions, etc. Finally, I tried a search in the SmartThings Community on “Security Mode greyed out” and came up with this thread. I too have an iPhone. Creating a scene, any scene, actually solved the problem for me as well! Just wish I’d found this sooner, but thrilled nonetheless that I found it at all!
That is awesome news! I’m glad I was able to contribute to a group I have gotten so much from.
Actually though, I think @rwwheaton made that final connection.
Glad it could work out!
Fantastic post!
I added a dummy scene and was able to disarm!
The text messaging still does not work though.
How are you using text message? I just tested an automation doing “If this then Txt msg” and it works. I did however have to allow ST to access the contacts.
Also, want country are you in? Text message is region restricted.
I’m in the US, Alabama.
I cannot tell if it sends this via text or email.
If it’s email, that’s a bit old style since no one sends something via email that needs to be seen immedately.
When you are setting up the IF section, first select “Notify Someone”. Then select “Send Text Message”. It looks like you selected “Send notification to members” instead. That open will send a notification within the SmartThings app. That’s not the option you want.
I agree with Bryan, I think you’re using the wrong vehicle. When you select “Send text message” it will ask to access the device’s contacts and you’ll add the contact name, That will then show the available phone #s for the contact. You select the one to receive the text.
