Not sure if this is the right place for this question, but I’m unable to install the lua st package.
I’m using luarocks, which is working fine for other packages, but when I run it for st I get
pi@mabpi:~/development/lua $ sudo luarocks install st
Installing https://luarocks.org/st-0.0-1.src.rock
st 0.0-1 depends on lua 5.3 (5.3-1 provided by VM)
st 0.0-1 depends on cosock (0.2.0-1 installed)
st 0.0-1 depends on dkjson (2.6-1 installed)
st 0.0-1 depends on logface (0.0.2-1 installed)
st 0.0-1 depends on luasocket >= 3.0-rc1 (3.1.0-1 installed)
st 0.0-1 depends on luasec >= 1.0 (1.2.0-1 installed)
st 0.0-1 depends on lua-yaml (1.2-2 installed)
st 0.0-1 depends on luxure (0.3.0-3 installed)
st 0.0-1 depends on lifter_puller (0.1.0-1 installed)
st 0.0-1 depends on xml2lua (1.5-2 installed)
Error: Build error: Failed installing init.lua in /usr/local/lib/luarocks/rocks-5.3/st/0.0-1/lua/st/init.lua: init.lua: No such file or directory
Any ideas what I can do?
