Hi, in my latest app when I add automation when leaving home the security mode can’t be chosen.
Hey there! @vagos1103gr,
Have you already tried resetting your Smart Things Home Monitor Security settings?
In your Home Monitor options>Security>Three Dot Menu,>Reset?
If the symptom persists, I would recommend trying a reinstallation of the ST application.
I hope this message finds you well!
^SamsungZell
I did reset and delete doesn’t help.
I had the same issue with changing the security mode in “THEN”. (iOS - iPhone) I added a fake “Scene” first - just made one called it “test” and action was “Change location’s mode → Home”. But I’m guessing guessing you can do any scene. Then the it suddenly started working. Give it a shot. Solved my issue
Thanks a lot this worked, you saved my day
