I decided not to worry about having ST initiate scripts on my Raspberry. I decided to have my sprinkler script remain controlled by cron/time and just added a line to reference a WebCore piston which checks for rain and wind. The piston turns on a single erocm1231 flashed Sonoff which makes the supply voltage to my other 5 4 channel Sonnoffs that are flashed espurna, if conditions are right. It works nicely and gives me the bit of “smart” function I was lacking.
I appreciate all the helpful posts and still intend to look into a few of the suggestions, especially node-red.
Found this in a Raspberry Pi group which makes your Pi discoverable as a WeMo device and will allow you to run python scripts but sadly I’ve got no idea how to code in python.
Yes. The MAC address is the pi’s. It will either be the the wireless or ethernet MAC depending on how your pi is connected to your network. Make sure the IP of the pi is being statically assigned by your DHCP server. How do you currently have omnithing configured (both locally and in the app)?
