Can I change state names for a virtual switch?
I am using an automation to control a virtual switch to show my persence. When I’m home the switch shows ON and when I’m away it shows OFF. Is there a way to change the state names to HOME and AWAY?
If you are using community created vEdge Creator, you can actually create a virtual presence sensor. Then your device status will be either Present or Not Present.
