Dear Community,
Can the click functions on the HomeSeer HS-WA100+ be assigned to different actions than the ones on the master HS-WS/WD (Concept: Using it as a “cheap” wire-powered smart home switch for arbitrary use in a remodel that is already wired for 3/4-way switching).
From the documentation and reading it looks like a double click on the WA100 just triggers the same event that the base would do. Is this correct? Or do they show up as different events?
