I have a TCL Roku TV that often needs to be rebooted. I have a custom Smartapp that accomplishes the task. I need a Routine that could be executed by Alexa that would run the Smartapp. Is is possible to use a Routine to accomplish this?
Sure, just have the routine turn on a virtual switch and have the smart app subscribe to the switch coming on.
Thank you! I set up the virtual switch. How do I have the smartapp subscribe to it coming on?
https://docs.smartthings.com/en/latest/smartapp-developers-guide/simple-event-handler-smartapps.html
preferences {
section {
input "theSwitch", "capability.switch"
def install() {
subscribe(theSwitch, "switch.on", switchOnHandler)
def switchOnHandler(evt) {
log.debug "switch turned on!"
Worked like a charm. Thanks!
