Here’s the full handler. So basically if I call PoolPumpOff() from a tile press the call makes it to the RPi and comes back through parse(). But if I call PoolPumpOff() from FountainModeOn() I never see it hit the RPi or parse(). Has to be something I’m missing.
I see it get called in the log below but it never makes it to the RPi so it never comes back to parse(). But again the same command works outside of the FountainModeOn() command.
e3a79e24-a7a4-4b50-aaea-d2eaeab3f833 5:05:40 PM: debug POST /macros/PoolPumpOff HTTP/1.1
Accept: /
User-Agent: Linux UPnP/1.0 SmartThings
e3a79e24-a7a4-4b50-aaea-d2eaeab3f833 5:05:40 PM: debug Executing hubAction on 192.168.1.171:8000
e3a79e24-a7a4-4b50-aaea-d2eaeab3f833 5:05:40 PM: debug Device Network Id set to c0a801ab:1f40
* Raspberry Pi Pool Controller
* Copyright 2019
* Control your pool equipment using a Raspberry Pi
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
import groovy.json.JsonSlurper
preferences {
input("ip", "string", title: "IP Address", description: "192.168.x.x", required: true, displayDuringSetup: true)
input("port", "string", title: "Port", description: "8000", defaultValue: 8000, required: true, displayDuringSetup: true)
metadata {
definition(name: "Pool Controller", namespace: "jaswalters", author: "Jason Walters") {
capability "Polling"
capability "Refresh"
capability "Temperature Measurement"
capability "Switch"
capability "Sensor"
capability "Actuator"
attribute "SuctionValvePos", "enum", ["SpaPos", "PoolPos"]
attribute "ReturnValvePos", "enum", ["SpaPos", "PoolPos"]
attribute "cpuPercentage", "string"
attribute "memory", "string"
attribute "diskUsage", "string"
attribute "FountainMode", "string"
attribute "RPiPower", "string"
attribute "cpuTemperature", "string"
attribute "memUsage", "string"
attribute "PoolPump", "string"
attribute "WaterFallMode", "string"
attribute "SpaMode", "string"
command "restart"
command "FountainModeOn"
command "WaterFallModeOn"
command "SpaModeOn"
command "PoolPumpOff"
command "PoolPumpOn"
simulator {
// TODO: define status and reply messages here
tiles(scale: 1) {
multiAttributeTile(name: "PoolPump", width: 1, height: 1) {
tileAttribute("device.PoolPump", key: "PRIMARY_CONTROL") {
attributeState "on", label: 'On', action: "PoolPumpOff", icon: "https://img.icons8.com/ios/50/000000/pump-filled.png", backgroundColor: "#00a0dc"
attributeState "off", label: 'Off', action: "PoolPumpOn", icon: "https://img.icons8.com/ios/50/000000/pump.png", backgroundColor: "#ffffff"
attributeState "turningOn", label: 'Turning On', icon: "https://img.icons8.com/ios/50/000000/pump-filled.png", backgroundColor: "#00a0dc"
attributeState "turningOff", label: 'Turning Off', icon: "https://img.icons8.com/ios/50/000000/pump.png", backgroundColor: "#ffffff"
valueTile("cpuTemperature", "device.cpuTemperature", width: 2, height: 2) {
state "temperature", label: '${currentValue}°F', icon: "https://img.icons8.com/wired/64/000000/processor.png", unit: "F"
standardTile("RPiPower", "device.RPiPower", width: 2, height: 2, decoration: "flat") {
state "off", label: 'Off', icon: "https://img.icons8.com/metro/50/000000/raspberry-pi.png", nextState: "on"
state "on", label: 'On', icon: "https://img.icons8.com/metro/50/000000/raspberry-pi.png", nextState: "off"
state "rebooting", label: 'Rebooting', icon: "https://img.icons8.com/metro/50/000000/raspberry-pi.png", nextState: "off"
valueTile("cpuPercentage", "device.cpuPercentage", width: 2, height: 2) {
state "default", label: '${currentValue}% CPU', icon: "https://img.icons8.com/wired/64/000000/processor.png"
standardTile("FountainMode", "device.FountainMode", width: 2, height: 2, decoration: "flat") {
state "off", action: "FountainModeOn", label: 'Fountain Mode Off', icon: "https://img.icons8.com/ios/24/000000/fountain.png"
state "turningOn", label: 'Turning \nOn', icon: "https://img.icons8.com/ios/24/000000/fountain-filled.png", backgroundColor: "#1e9cbb"
state "turningOff", label: 'Turning Off', icon: "https://img.icons8.com/ios/24/000000/fountain.png"
state "on", action: "FountainModeOn", label: 'Fountain Mode On', icon: "https://img.icons8.com/ios/24/000000/fountain-filled.png", backgroundColor: "#1e9cbb"
standardTile("WaterFallMode", "device.WaterFallMode", width: 2, height: 2, decoration: "flat") {
state "off", action: "WaterFallModeOn", label: 'WaterFall Mode \nOff', icon: "https://img.icons8.com/ios/50/000000/waterfall.png"
state "turningOn", label: 'Turning \nOn', icon: "https://img.icons8.com/ios/50/000000/waterfall-filled.png", backgroundColor: "#1e9cbb"
state "turningOff", label: 'Turning Off', icon: "https://img.icons8.com/ios/50/000000/waterfall.png"
state "on", action: "WaterFallModeOn", label: 'WaterFall Mode \nOn', icon: "https://img.icons8.com/ios/50/000000/waterfall-filled.png", backgroundColor: "#1e9cbb"
standardTile("SpaMode", "device.SpaMode", width: 2, height: 2, decoration: "flat") {
state "off", action: "SpaModeOn", label: 'Spa Mode \nOff', icon: "https://img.icons8.com/ios/50/000000/spa.png"
state "turningOn", label: 'Turning \nOn', icon: "https://img.icons8.com/ios/50/000000/spa-filled.png", backgroundColor: "#1e9cbb"
state "turningOff", label: 'Turning \nOff', icon: "https://img.icons8.com/ios/50/000000/spa.png"
state "on", action: "SpaModeOn", label: 'Spa Mode \nOn', icon: "https://img.icons8.com/ios/50/000000/spa-filled.png", backgroundColor: "#1e9cbb"
valueTile("diskUsage", "device.diskUsage", width: 2, height: 2) {
state "default", label: '${currentValue}% Used', unit: "Percent", icon: "https://img.icons8.com/ios/50/000000/sd.png"
valueTile("memUsage", "device.memUsage", width: 2, height: 2) {
state "default", label: '${currentValue}% Used', icon: "https://img.icons8.com/ios/50/000000/brain.png"
standardTile("restart", "device.restart", width: 3, height: 1, inactiveLabel: false, decoration: "flat") {
state "default", action: "restart", label: "Restart", displayName: "Restart"
standardTile("refresh", "device.refresh", width: 3, height: 1, inactiveLabel: false, decoration: "flat") {
state "default", action: "polling.poll", icon: "st.secondary.refresh"
standardTile("emptyfiller", "null", width: 2, height: 2, decoration: "flat") {
state "empty", label: '', defaultState: true
main "PoolPump"
details(["PoolPump", "FountainMode", "WaterFallMode", "SpaMode", "RPiPower", "cpuTemperature", "cpuPercentage", "diskUsage", "emptyfiller", "memUsage", "restart", "refresh"])
def map = [: ]
def descMap = parseDescriptionAsMap(description)
def body = new String(descMap["body"].decodeBase64())
def slurper = new JsonSlurper()
def result = slurper.parseText(body)
log.debug "result ${result}"
if (result) {
if (state.reboot == "true") {
state.reboot = "false"
log.debug "Pool controller is up"
sendEvent(name: "RPiPower", value: "on")
} else {
log.debug "The Raspberry Pi may be offline!"
log.debug "RPi Power Status: stringValue: ${device.currentState("RPiPower").stringValue}"
if (result.PoolPump == "On") {
log.debug "PoolPump: ${result.PoolPump}"
state.PoolPump = "on"
sendEvent(name: "PoolPump", value: "on")
else if (result.PoolPump == "Off")
state.PoolPump = "off"
sendEvent(name: "PoolPump", value: "off")
if (result.cpu_temp) {
log.debug "cpu_temp: ${result.cpu_temp}"
sendEvent(name: "cpuTemperature", value: result.cpu_temp)
if (result.cpu_usage) {
log.debug "cpu $result.cpu_usage"
sendEvent(name: "cpuPercentage", value: result.cpu_usage)
if (result.mem_usage) {
log.debug "mem_usage: ${result.mem_usage}"
sendEvent(name: "memUsage", value: result.mem_usage)
if (result.disk_usage) {
log.debug "disk_usage: ${result.disk_usage}"
sendEvent(name: "diskUsage", value: result.disk_usage)
log.debug "mode ${result.Mode}"
if (result.Mode && state.reboot != "true") {
//log.debug "My state = ${state.refresh}"
if (result.Mode == "FountainModeOff") {
sendEvent(name: "FountainMode", value: "on")
if (device.currentState("FountainMode").stringValue == "on") {
//Save the valve postion to state object
state.Mode = "FountainMode"
sendEvent(name: "WaterFallMode", value: "off")
sendEvent(name: "SpaMode", value: "off")
} else if (result.Mode == "WaterFallModeOff") {
sendEvent(name: "WaterFallMode", value: "on")
if (device.currentState("WaterFallMode").stringValue == "on") {
state.Mode = "WaterFallMode"
sendEvent(name: "FountainMode", value: "off")
} else if (result.Mode == "SpaModeOff") {
sendEvent(name: "SpaMode", value: "on")
if (device.currentState("SpaMode").stringValue == "on") {
state.Mode = "SpaMode"
if (result.Mode == "FountainMode")
sendEvent(name: "FountainMode", value: "turningOn")
GetIncomingMode(state.Mode)
} else if (result.Mode == "WaterFallMode") {
sendEvent(name: "WaterFallMode", value: "turningOn")
} else if (result.Mode == "SpaMode") {
sendEvent(name: "SpaMode", value: "turningOn")
log.debug "Pool valves have been set to ${state.Mode}"
if (state.refresh == "true")
GetValveMode(state.Mode)
state.refresh = "false"
def PoolPumpOff()
if (state.reboot != "true")
sendEvent(name: "PoolPump", value: "turningOff")
def uri = "/macros/PoolPumpOff"
postAction(uri)
log.debug "made it here"
def PoolPumpOn()
if (state.reboot != "true" && CheckModeState() == "true")
sendEvent(name: "PoolPump", value: "turningOn")
log.debug "fountain on"
def uri = "/macros/PoolPumpOn"
postAction(uri)
def CheckModeState()
if (device.currentState("SpaMode").stringValue == "on" || device.currentState("FountainMode").stringValue == "on" || device.currentState("WaterFallMode").stringValue == "on")
return "true"
else
return "false"
//Sends post request to raspberry webiopi to turn on fountain via turnvlaves macro script
def postFountainMode() {
if (state.reboot != "true") {
def uri = "/macros/FountainModeOn"
postAction(uri)
def FountainModeOn()
if (CheckModeState() == "true")
if (device.currentState("PoolPump").stringValue == "on")
PoolPumpOff()
if (device.currentState("PoolPump").stringValue == "off")
def hubActions = [postFountainMode(), delayAction(10000), postFountainModeOff()]
hubActions
def GetIncomingMode(Mode) {
switch (Mode) {
case "FountainMode":
sendEvent(name: "FountainMode", value: "turningOff")
break
case "WaterFallMode":
sendEvent(name: "WaterFallMode", value: "turningOff")
break
case "SpaMode":
sendEvent(name: "SpaMode", value: "turningOff")
break
def postFountainModeOff() {
if (state.reboot != "true" && device.currentState("RPiPower").stringValue == "on") {
log.debug "fountain off"
def uri = "/macros/FountainModeOff"
postAction(uri)
def postWaterFallModeOn() {
//sendEvent(name: "WaterFallMode", value: 'turningOn')
def uri = "/macros/WaterFallModeOn"
postAction(uri)
def WaterFallModeOn()
def hubActions = [postWaterFallModeOn(), delayAction(10000), postWaterFallModeOff()]
hubActions
def postWaterFallModeOff() {
def uri = "/macros/WaterFallModeOff"
postAction(uri)
def postSpaModeOn() {
def uri = "/macros/SpaModeOn"
postAction(uri)
def postSpaModeOff() {
def uri = "/macros/SpaModeOff"
postAction(uri)
def SpaModeOn()
def hubActions = [postSpaModeOn(), delayAction(10000), postSpaModeOff()]
hubActions
def poll() {
log.debug "Executing 'poll'"
log.debug "reboot ${state.reboot}"
state.refresh = "true"
sendEvent(name: "RPiPower", value: "off")
sendEvent(name: "PoolPump", value: "${state.PoolPump}")
getRPiData()
def refresh() {
log.debug "Executing 'refresh'"
poll()
def restart() {
log.debug "Restart was pressed"
if (device.currentState("RPiPower").stringValue != "off") {
state.reboot = "true"
sendEvent(name: "RPiPower", value: "rebooting")
def uri = "/macros/rebootRPi"
postAction(uri)
def GetGPIOStatus()
def uri = "/macros/GetGPIOStatus"
postAction(uri)
// Get Raspberry Pi stats
private getRPiData() {
def uri = "/macros/getRPiData"
postAction(uri)
//Gets the postion of the valve from state.ReturnValvePos
def GetValveMode(ValveState)
if (ValveState == "FountainMode") {
} else if (ValveState == "SpaMode") {
} else if (ValveState == "WaterFallMode") {
private postAction(uri) {
setDeviceNetworkId(ip, port)
def hubAction = new physicalgraph.device.HubAction(
method: "POST",
path: uri
log.debug("Executing hubAction on " + getHostAddress())
log.debug hubAction
return hubAction
def parseDescriptionAsMap(description) {
description.split(",").inject([: ]) {map,param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()): nameAndValue[1].trim()]
private delayAction(long time) {
new physicalgraph.device.HubAction("delay $time")
private setDeviceNetworkId(ip, port) {
def iphex = convertIPtoHex(ip)
def porthex = convertPortToHex(port)
device.deviceNetworkId = "$iphex:$porthex"
log.debug "Device Network Id set to ${iphex}:${porthex}"
private getHostAddress() {
return "${ip}:${port}"
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize('.').collect {
String.format('%02x', it.toInteger())
}.join()
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format('%04x', port.toInteger())
return hexport
