Calibrate temperature on Third Reality temperature/humidity sensor
Anyone using a Third Reality 3RTHS24BZ temperature and humidity sensor and notice that the temperature is a bit off? Mine reads about 1.5*F low, relative to a Thermworks digital thermometer. The ST Advanced Web page has a parameter for temperature offset but I cannot find a way to actually adjust it.
There’s no temperature offset setting in the device’s preferences (device card → three dots → …)?
Fingerprint:
  - id: "Third Reality/3RTHS24BZ"
    deviceLabel: ThirdReality Temperature and Humidity Sensor
    manufacturer: Third Reality, Inc
    model: 3RTHS24BZ
    deviceProfileName: humidity-temp-battery
Device profile:
components:
- id: main
  capabilities:
  - id: temperatureMeasurement
    version: 1
  - id: relativeHumidityMeasurement
    version: 1
  - id: battery
    version: 1
  - id: firmwareUpdate
    version: 1
  - id: refresh
    version: 1
  categories:
  - name: TempHumiditySensor
preferences:
  - preferenceId: tempOffset
    explicit: true
  - preferenceId: humidityOffset
    explicit: true
deviceConfig:
  dashboard:
    states:
      - component: main
        capability: temperatureMeasurement
        version: 1
        group: main
        composite: true
      - component: main
        capability: relativeHumidityMeasurement
        version: 1
        group: main
        values:
          - label: "  {{humidity.value}} {{humidity.unit}}"
        composite: true
    actions: []
    basicPlus: []
  detailView:
    - component: main
      version: 1
    - component: main
      version: 1
    - component: main
      capability: battery
      version: 1
    - component: main
      capability: refresh
      version: 1
  automation:
    conditions:
      - component: main
        version: 1
      - component: main
        version: 1
      - component: main
        capability: battery
        version: 1
    actions: []
So there must be a setting.
You nailed it–there are offset settings for both temperature and humidity there! Doh, it never occured to me to look there. Thanks very much.
