As I’m saying this… even the physical buttons stopped working. How can someone release an update the breaks such a crucial part of this device eco system and then take more than a week to launch a fix?
For me this touches on unacceptability. Parts of the house lights are not working as intended and half the family will complain that the whole system does not work. If it’s that fragile then I’m not sure how capable it is.
Im having this exact same issue. I see the buttons and key presses, but cannot edit the pressed/held events anymore and the buttons just stopped working a couple days ago. I dont think the iOS update specifically messed it up as my work phone is older and same issues when I login to smartthings on that as well, and the app was last updated 3 weeks ago. I think someone borked the backend server plugins as the buttons execute their code via the cloud and not locally.
Now the question is on who maintains that plugin, my support inquiry to Samsung said it wasnt a supported thing so I think someone wrote it and just got it published via the Web IDE to be publicly usable. However, I did install the CoRE Smartapp and that seems to have allowed my buttons to work with the pistons via the new app so going to set all of them up on that to get everything working again.
My issue is similar with two Smartthings buttons. I can edit the actions and when the button is pressed it shows that it was pressed in the app but nothing happens. I have two buttons controlling two separate lights and both stopped working last night. I can turn the lights on and off from the app just fine.
What do you mean by plugin? This happens on my IKEA TRÅDFRI Remote which is supported. The inability to edit started happening immediately after updating the app a few days ago, and the buttons themselves stopped working yesterday.
The same happens on three different buttons and two different DH so I’m sure the issue is deeper
Developer support isn’t really the proper channel for this IMO. We aren’t developers with questions about APIs, capabilities, etc. This should be handled by the normal customer support channel.
Actually, if you look at the list of officially supported things (https://www.smartthings.com/products/-/filter/brands/ikea), the buttons are not on it. What I mean by plugin is if the developer that wrote the “IKEA Button” type may be the one who has to fix it as I do not know if Samsung officially authored that handler, or if it was a submitted development thats available to the public.
I did however get CoRE SmartApp installed and a piston configured and that does seem to be working so far at least with the one test button I setup.
So you are having this issue with the actual Smartthings branded buttons? Zohar, prjct92eh2, and myself are having this issue regarding the IKEA 5 button remotes.
Yes, the Smartthings branded buttons. The app shows that the button was pressed but the light doesn’t toggle. I tried removing and re-adding the action but that didn’t help.
I have the same issue, Smartthings branded buttons stopped responding properly to physical press. I worked out that for me it’s to do with “switching state” of devices when pressing the button. If I do a single press it switches state but then a second single press doesn’t switch it again. To make the ‘single press device’ switch state again I need to do a double press (which switches a different device) and then go back and try a single press again, which then works. Same issue if I start with double press, I can’t then double press again without doing a different action first. Not sure if others with Smartthings buttons not working are experiencing same thing?
