I found this product which uses Smart Life instead of ewelink. Not sure if it is reliable but I seem to have better luck with Smart Life plugs than any ewelink switch. Although it’s not direct integration, maybe this is the only thing I can find
What I mean is a switch (wifi, zwave or ZigBee,) that has two or more Load inputs that go to different lights and the switch fits in a one gang in wall box. Easy to integrate to ST. I’m looking to replace the ewelink switches which are terrible in my case.
Thanks so much! They do have a U.S. size 1 gang switch with two buttons and two loads. That maybe the best one I’ve seen and already has integration with Smartthings.
A quick word on budget brands in zwave light switches that have come out since this thread was originally started.
In addition to GE, I would definitely look at in Inovelli and Zooz. Both tend to be less expensive than the GE but using newer technology. (And if you are on a really tight budget and you have a lot of three-way switches, some Zooz models can be wired with one master switch and use your existing dumb accessory switches, an additional cost savings.)
Zooz is a house brand for the Smartest House. You can normally get your best price from them, and if you need a dozen or more write to them and see if they can get you a quantity discount.
The following thread discusses options for an inwall receptacle where the two sockets can be independently controlled. Not plug-in modules.
Before anybody gets too excited, while there is one model that works in the UK and one model that works in the US, they both rely on IFTTT for integration with SmartThings. So cloud to cloud. Interestingly, they both also offer HomeKit integration, so if you happen to use iOS devices you can use that as a local backup. But otherwise, yes, cloud-dependent.
I have 19 overhead lights in my basement, which are currently controlled by 4 switches (no 3-way). All of the lights currently have Osram Color Temperature bulbs installed.
I want to install smart switches, and wire the fixtures to be always on and simply control using Smartthings rather than directly to the switch. I will then use the multi tap and hold features of the Homeseer switches to trigger scenes in Smartthings across all of the lights.
Can I buy Homeseer HS-WA100+ switches (add-ons) instead of HS-WS100+ switches? I know that if I were using the switches to control load to the fixture, I would need WS100+, but I am not doing that here.
The add-on’s are about $20 less so I was hoping to save if they met my needs. I specifically want to have multi-tap and press/hold features on each light switch.
As of this writing, all of the sirens on the official compatibility list are zwave. The following 2019 thread has a discussion of some Wi-Fi and zigbee siren options if anybody needs those:
Brief 2019 discussion of bright smart bulbs that don’t require an additional Bridge/gateway/hub when using SmartThings. Applies to both the US and the UK.
