There aren’t a lot of options for ceiling fan control that work with SmartThings, but there are two good ones and some that are OK if the first two don’t work with your wiring. See the following thread:
Detailed discussion of leak sensors:
Detailed discussion of pocket socket options for the UK:
More about Smart Bulbs.
Looks to be that the GE is the most common brand for switches… Ge Smart switch with dimmer and wanted to know the following:
I would like to install this in a light that is controlled by 2 switches (different locations) and wanted to know if I have to install 2 of these or just one (leaving a dummy one) so I can make it work with z wave?
See the following (this is clickable link)
And then you can ask any follow on wiring questions in the following thread:
Discussion thread comparing Amazon echo with google home:
Just an update on zwave motion sensors. @krlaframboise has recently done an extensive review of six different models including features like detection zone range. This doesn’t include any zigbee sensors, but it’s well worth the read.
https://www.thesmartesthouse.com/blogs/the-smartest-blog/the-best-z-wave-motion-sensors-compared
Besides the Dome bullet point that sounds like I wrote when I was drunk, there’s a correction that should be made to that Blog post.
The chart at the bottom shows 1-255 Minutes for the motion re-trigger wait time of the Zooz Z-Wave Plus Motion/Humidity/Temp/ Light Sensor, but that’s no longer correct.
Firmware version 17.9 was released a couple of weeks ago and it changes the motion re-trigger wait time to 15-60 Seconds.
We’ll edit it!
A 2018 thread discussing various thermostat options, mostly by referral to previous forum threads:
And a thread discussing the various brands and models of water valve shut off devices:
A thread discussing some options for acoustic sensors:
Several questions recently about a multi button scene controller that will fit in a single gang spot. I think these are going to be even more popular now that smartthings has added the scenes feature. So here’s a discussion thread for those:
The following thread discusses security keypad options, including the iris keypad and the zipato keypad.
The Iris keypad is zigbee, and has multiple features including a beep and an indicator LED which can be set to show you if the ST security features are armed.
The Zipato keypad is available on both the US and UK zwave frequencies. It has fewer features than the iris device, but it does also work with a Keyfob that you just touch to the device, so some people prefer it for that reason.
For more details on either, see the thread linked to above.
Discussion of outdoor-rated smart bulbs. Although most people use a smart switch with dumb bulbs for outdoor lighting, some people are looking for an outdoor bulb to act as a repeater for devices in an outbuilding, or may want color changing or zone capability.
2018 thread discussing options for smart blinds:
Electric Radiator control options for the US:
Are the thermostats for these electric radiators integrated into them? Do you have a link to the product you have?
When A link is provided to a discussion thread about a particular device class, please ask any follow-up questions in that discussion thread. I can’t help you as I don’t have those devices myself. I was just giving the link to the thread where they are discussed.
