Bug report, UI and ST device status reporting issues
This was present in the last app as well, where everywhere you see the option ‘Only if switch is’ on or off. I pick either one, switch on and another attempt, switch off, and it never shows what I set it to. The only thing that stays in that field is ‘Tap to set.’. ??
Any screen shots?
The Only if switch never stays, and neither does the mode. I can set it, save it, Done, and when I come back to it, it’s as you see.
All of this is under Automations.
