I am trying to use the Notify if Unlocked code and it works, with the exception of sending the optional SMS message…and I can’t figure out what the issue is. The error message being logged is as follows.
c0ba4b58-d68c-49f3-9085-242f2e847050 10:50:45 AM CST: error groovy.lang.MissingMethodException: No signature of method: script14177118442451333570032.sendSMS() is applicable for argument types: (java.lang.String, org.codehaus.groovy.runtime.GStringImpl) values: [(999) 999-9999, Breezeway Door is left unlocked and closed for more than 1 minutes.]
Possible solutions: sendSms(java.lang.String, java.lang.String), sendSms(java.lang.String, java.lang.String, java.util.Map), sendPush(java.lang.String), sendPush(java.lang.String, java.util.Map) @ line 108
c0ba4b58-d68c-49f3-9085-242f2e847050 10:50:45 AM CST: debug Sending text message.Breezeway Door is left unlocked and closed for more than 1 minutes.
c0ba4b58-d68c-49f3-9085-242f2e847050 10:50:44 AM CST: trace Sending the notification: Breezeway Door is left unlocked and closed for more than 1 minutes…
c0ba4b58-d68c-49f3-9085-242f2e847050 10:49:51 AM CST: trace Scheduling ‘notifyUnlocked’ for InstalledSmartApp: c0ba4b58-d68c-49f3-9085-242f2e847050
c0ba4b58-d68c-49f3-9085-242f2e847050 10:49:49 AM CST: trace Deleting scheduled job ‘notifyUnlocked’ for InstalledSmartApp: c0ba4b58-d68c-49f3-9085-242f2e847050
c0ba4b58-d68c-49f3-9085-242f2e847050 10:49:49 AM CST: debug Starting the countdown for 1 minutes…
Anyone have any recommendations/thoughts on what the issue is here?
I’ve copied the code below for reference. Any help is appreciated.
Thanks in advance. - Kevin
- Notify If Left Unlocked
- Copyright 2014 George Sudarkoff
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
definition(
name: “Notify If Left Unlocked”,
namespace: “com.sudarkoff”,
author: “George Sudarkoff”,
description: “Send a push or SMS notification (and lock, if it’s closed) if a door is left unlocked for a period of time.”,
category: “Safety & Security”,
iconUrl: “http://www.kevinwestby.com/smartthings/securehome1-120.png”,
iconX2Url: “http://www.kevinwestby.com/smartthings/securehome1-120.png”,
iconX3Url: “http://www.kevinwestby.com/smartthings/securehome1-120.png”)
preferences {
section(“If this lock…”) {
input “aLock”, “capability.lock”, multiple: false, required: true
input “openSensor”, “capability.contactSensor”, title: “Open/close sensor (optional)”, multiple: false, required: false
section(“Left unlocked for…”) {
input “duration”, “number”, title: “How many minutes?”, required: true
section(“Notify me…”) {
input “pushNotification”, “bool”, title: "Push notification"
input “phoneNumber”, “phone”, title: “Phone number (optional)”, required: false
input “lockIfClosed”, “bool”, title: “Lock the door if it’s closed?”
def installed()
initialize()
def updated()
unsubscribe()
initialize()
def initialize()
log.trace "Initializing with: ${settings}"
subscribe(aLock, “lock”, lockHandler)
def lockHandler(evt)
log.trace "${evt.name} is ${evt.value}."
if (evt.value == “locked”) {
log.debug "Canceling lock check because the door is locked…"
unschedule(notifyUnlocked)
else {
log.debug "Starting the countdown for ${duration} minutes…"
state.retries = 0
runIn(duration * 60, notifyUnlocked)
def notifyUnlocked()
// if no open/close sensor specified, assume the door is closed
def open = openSensor?.latestValue(“contact”) ?: “closed”
def message = "${aLock.displayName} is left unlocked and ${open} for more than ${duration} minutes."
log.trace "Sending the notification: ${message}."
sendMessage(message)
if (lockIfClosed) {
if (open == "closed") {
log.trace "And locking the door."
sendMessage("Locking the ${aLock.displayName} as prescribed.")
aLock.lock()
else {
if (state.retries++ < 3) {
log.trace "Door is open, can't lock. Rescheduling the check."
sendMessage("Can't lock the ${aLock.displayName} because the door is open. Will try again in ${duration} minutes.")
else {
log.trace "The door is still open after ${state.retries} retries, giving up."
sendMessage("Unable to lock the ${aLock.displayName} after ${state.retries} retries, giving up.")
def sendMessage(msg) {
if (pushNotification) {
sendPush(msg)
if (phoneNumber) {
sendSMS(phoneNumber, msg)
