Since we were told there would be parity with the features in the classic app before it was removed, but it has now been removed and there are still multiple items that don’t work in the new app, and things have changed many times, I wanted to go ahead and create a new thread that would round up the current missing pieces. Please feel free to add to this.
smartLighting is region locked and now not available in several countries where it used to be available. This includes some of the Nordic countries. There does not seem to be an official list anywhere of which countries do get smart lighting.
virtual presence sensors cannot be used as trigger conditions for automations. You can enter the information but it doesn’t save. Even worse, there are reports that it gets swapped out for the UI device’s presence feature, which could be dangerous.
Multi button devices, both zigbee and Z wave, frequently lack support for all but one button. There are some DTH changes that can help with this, but there doesn’t seem to be an official writeup anywhere of what the required changes are.
some Smart Home Monitor (SHM) features operated locally in the classic app. It now appears that all of the equivalent smartthings home monitor (STHM) features are cloud-based.
“After things quiet down“ or “after no motion” automations appear to work differently in the new app and not all use cases can be solved.
if you are using smart lighting with all local devices and you use a delay, the devices may be triggered Serially rather than in parallel.
there is now a limit of a maximum of 200 devices. You will get an error message if you try and add a 201st device. This was not true in the classic app. (As @prjct92eh2 noted below, this still works in some places in the new app, so whether you run into it or not depends in part just how you use the app.)
several Fibaro devices do not appear to work correctly with the new app.
in the old app you could specify which devices you wanted exposed to Alexa. That is no longer true. @iridris adds this is also true for Google.
automations with multiple presence checks in the If statement do not appear to work. People are ending up creating one automation for each person, which doesn’t always have the same result.
momentary buttons using the stock DTH no longer work. They frequently create execution loops, probably because they are stateless.
speaking of state… If a device, including a scene from some of the cloud to cloud integrations, doesn’t have an initial state it shows as off-line in the new app and can’t be added to an automation. The workaround for this is to use web core or sharptools to turn the device on for the first time.
Fan speed can’t be used in a scene
Voice accessibility is a problem in many places in the app
If automations are created from the device page, then The main page will take a very long time loading.
there are still reports of the app using huge amounts of storage but I’m not 100% sure of the details of that.
widgets and watch apps are missing relative to what was available with the classic app
“left open” (as opposed to “if open”) functionality is missing from the new app
multiple reports in the forum that scenes from the new app are not working with Google assistant, but I don’t know all the details on that
quite a few individual client devices (phones/tablets/watches) that worked with the classic app do not work with the new V3 app. Even some from Samsung itself.
cannot change the icons for Devices
for a multi capability device, cannot specify which capability is highlighted on the tile.
Smartlocks is now region locked, and apparently Canada is one of the countries that no longer has this functionality?
custom DTHs can go “stale” causing multiple issues for the device.
everyone on the account has to live in the same country. This did not used to be true and has caused problems for some members in Europe.
(from @nezmo below)
No way to see a complete list of apps and automations any one device is being used in. -
(from @nezmo)
No zwave replace utility -
offsets/delays of more than 60 minutes. In the classic app, a number of members had routines that had delays or offsets of 90 minutes or more. I remember one where if the mode was away for more than 12 hours it would change to vacation mode. Also some relative to sunset. In the new V3 app, these sort of offsets can only go up to 60 minutes. One staff member posted that this was an intentional UI change, but it did remove functionality that existed under the classic app. I’m going to go ahead and link to this one because it’s hard to find with a search.
(from @rontalley )
No way to reset kWh Meter using stock Power Monitor Plug -
(from @rontalley )
Lost the ability to see if other members are home or not because their phones no longer show as devices. There are workarounds with custom code, but this was base functionality in classic.
(From @Shinedown78 )
Device activity history doesn’t show what automation triggered the device (i.e. webcore piston, smartlighting automation etc), making troubleshooting a nightmare… -
(From @saosinx88 )
setting an automation with period of time can’t have a set time and sunset/sunrise, such as an automation that is triggered between sunset and 11 pm. You either have to use one or the other. This is a change from classic. -
(From @PaulmacUK )
Device History (android app) Listed history for sleepy end devices does not show reports of battery status / level, even though the device is reporting the battery level correctly.
Each of the issues above has been discussed in some detail in the forums if you want to look for those conversations.
Each of these falls into the “worked for months/years, I didn’t change anything except going to the new app, now it doesn’t work” category.
Again, please feel free to add more if you know of them. Also if you want to add a link to a discussion thread, that’s good too.
