Makes sense - copy of code would be appreciated. Does that mean using multiple device handlers or will it handle switches as well?
Itâs really annoying to have to join the crew of not getting this working - Even when following the instructions.
Iâve managed to learn the Codes on RM bridge, but its getting that into Smartthings that seem to be the issue.
Any help would be much appreciated.
Where its failing, need more info to help you. Do you have Hub or using cloud ? What code you are using. Try using below
I believe its stalling when it comes to Smartthings. I have the RM Pro hub local and Smartthings hub local. Iâve got my Android tablet running RM Bridge and have managed to learn the âMonitor Lights Onâ and âMonitor Lights Offâ commands on the RM Bridge web interface. I think its after this that Iâm getting stuck (or its not working).
Iâve installed the device handler (both yours and Rebeccaâs one), âRM Bridge Switch LANâ to the correct def_URL1 to (def url1=â192.168.0.##:7474â)
Then Iâve added a device to my things list and set the following (This is where I think Iâve gone wrong):
Now Iâm not sure if this part is correct or if Iâve labeled it wrong or not?
Thanks for your help to this point though!
Here is what you need to do to control TV volume using simulated dimmer.
- Learn IR code in RM Bridge. Give code name like âVOLUME upâ for volume up and âVOLUME downâ for volume down
- Add below device handler in IDE
https://github.com/itsamti/MySmartthingsApps/blob/master/RM%20Bridge%20VOLUME%20LAN - Create switch called VOLUME in IDE device and use âRM Bridge VOLUME LANâ device type. Make sure you will give Device network id as âVOLUMEâ as given in step 1.
- Create Dummy Dimmer. I am using below device handler and then creating dimmer device in IDE
https://github.com/itsamti/MySmartthingsApps/blob/master/RM%20Virtual%20Dimmer
Name dummer as âHome Theaterâ (you can use your own name as you like" - Go to IDE Smart App and save/publish below code
https://github.com/itsamti/MySmartthingsApps/blob/master/RM%20Volume - Finally Go to Smartthings App -> Marketplace -> SmartApp -> My Apps and find RM Volume
Use Master Dimmer Switch as "Home Theater"
Use Slave as VOLUME switch you created in step 3
Give any name to App
Press done. - Give access to Echo
All setup is complete now.
Very Imp - Now set dimmer to 0 in smartthings, wait for 1-2 mins. Broadlink RM will send VOLUME down command and make TV volume 0.
Now you can say âAlexa, Set Home theater to 25â etc⊠etc. It should work.
This helps.
Remove âOnâ from Device Network Id. You just need to give âMonitor Lightsâ in network id, on/off will be handled internally when you press that switch.
Another thing, try using lower case on/off. So your command in RM Bridge should say âMonitor Lights onâ and âMonitor Lights offâ. This may not be needed as REST API commands are not case sensitive.
For debugging, type http://192.168.0.##:7474/code/Monitor%20Lights%20on on google chrome on same network and see if it turns on light.
Iâve removed the âOnâ from the Device ID. Still nothing - Used the links you provided and it does turn my lights on and off.
Will try making the RM Bridge command a lower case on and off.
Bingo! - I recreated the RM Bridge commands with lowercase on and off, also change the Device stuff in ST to the following:
So I removed the on from âNameâ and âDevice Network IDâ like you suggested. Works a charm!
Yeeey!!! Congratulations!
This is amazing! Thank you so much! Finally, this is just great!
Do you know if RM Bridge can control the 433mhz stuff that RM Pro can control?
If so, Iâve got loads more I can do
I think so. Rm Bridge is nothing but just connection between RM Pro and Smartthings. Actual commands are being sent by RM Pro. RM pro can send 433 and 315 mhz.
I can tell in my case, I had programmed below so far
- etekcity switches
- X10 devices
- Have old security system (Secured by Sam), I have programmed it and re-using it as Samrtthings alarm. Had to write alarm device handler
- RF wireless doorbell
https://www.amazon.com/dp/B01M7RMWLX/ref=twister_B01J9ZT336?_encoding=UTF8&psc=1
I had been using them as my doorbell before i got ring doorbell. Now since I have ring, didnt wanted to throw these so I am reusing it with Ring doorbell. If anyone rings my ring doorbell, smartthings rings these. "you can call them poor manâs ring chimes "
Also using few other switches that came with RF motion sensor . I got motion sensor learned with RM Pro.
Yep, confirmed!
Had to do an extra step where by I had to use the âFrequency Scanâ option while hitting the button on the original remote, that then âdidnâtâ error and allowed me to learn the commands!
Love this!
Frequency Scan is mandatory for RF learning.
Ahh see I didnt know that!
Has anyone tried this?
Curious how this works and the placement of the device. For RF i assume you can conceal it but what about IR.
Hi,
I made a device handler for Broadlink RM Pro which is using one of RM plugin, RM Bridge and Home Assistant.
Because it doesnât use a smartapp and you can input a device URI in PC, it may be easy to work.
I wish it to help you.
It has 7 transmitters which give decent all round (line of sight) coverage within one room. Central placement should theoretically work best, but with my own usage I have one device that has a really poor range on its remote, that range didnât improve with the broadlink so that affected placement and it wasnât centrally locatedâŠ
If there were multiple devices like that at certain places in a large room then I guess that scenario is where it wouldnât work well.
Hello,
How can i control curtain (two bottom: up / down) by one bottom of tc2 ??
Im having some issues with my setup wich I think are casued because of the Android Device im using.
All of a sudden the Broadlink RM PRO stops receiving commands from ST. I then check if the Android device is still connected to the network and its not, I need to reset it. Does anyone else have this problem?
Im using the DOLAMEE D5 Android TV Box
Tanks!
