RM3 supports rolling codes and more frequencies then only 315 and 433. Thanks for confirmation that it works with RM Tasker.
I am not sure if it works with RM Tasker. I can see the device, but when I try to pull the remote commands I have already included into the eRemote app, it tells me that I have nothing in the eRemote app.
Will only be able to test it properly next weekend.
In terms of the frequencies, the one I received has only 315 and 433 as RF frequencies written on the back of the device.
I have the remote
Http://www.ebay.it/itm/Nuovo-Telecomando-slim-Micronova-standard-Micronova-Extraflame-Evacalor-ecc-/261748721918
I have cloned the keys with a rm2 broadlink.
But I have a problem the power key, it has to be pressed 4 seconds
And I do not get it, Someone knows how I can memorize a press of 4 seconds on a key
Thank you
I have now setup my RM Pro with smartthings using the github code. It works great. I have also included the new switches from smartthings into my logitech harmony. So my logitech harmony can now control RF Devices .
When I turn on an activity with projector, the projector screen which is RF based, automatically comes down.
[quote=âsorensâ]Turns out itâs possible to remove the Android bridge requirement. This python library (https://github.com/mjg59/python-broadlink) allows you to send codes directly to the RM.
I wasnât able to get it to learn new RF codes, so I used the RM Bridge android app to get the hex RF codes I need. Then the python library sends them just fine to my RM2.
Also, since I now donât have to use RM Bridge, itâs relatively simple to interact with the RM2 from outside my local network.[/quote]
AWESOME FIND.
is there any guild to integrate for this setup?
I would be interested too if there is a guide to integrate this into ST. I couldnât really make out what needs to be done based on the github page.
I too am interested in a guide for this. I have a âBroadlink RM2 Pro Rm2 RF+IRâ that Ive been wanting to integrate (without an android bridge).
Hi - Iâve gone down the RMPro / RM Bridge / SmartThings / Alexa route but canât seem to get everything working together. The gap seems to be between SmartThings and RM Bridge and sure Iâve probably missed a step. Iâve successfully added TV to devices on SmartThings and Alexa recognises my simple addition âTVâ. Iâve successfully added the TV on & off codes to RM Bridge. What Iâm not fully able to figure is how SmartThings communicates with RMPro - this is the bit I think is not working and struggling to figure why. If i say âTV ONâ Alexa responds âOkayâ so that side is âworkingâ. One thing I noticed is that TV doesnât appear in eControl - shouldnt it pick this up having added to RM Bridge? I think once I overcome this hurdle then the logic will fall together and hopefully have a âah-haâ moment. Thanks!
Tried the smarthings arduino route with RF modules. Tried the Raspberry Pi running Home Assistant. The latter go the furthest but I think I have rolling code RF remotes.
Canât wait for this to get integrated to Smartthings.
E-control is not needed. Did you try RM Bridge manage code page and tested from there and see if TV turns on ?
Hi - Iâve loaded a couple of codes to the RM Bridge site along with the
external IP:7474. This tests okay and operates the TV Power. One for âTV
onâ and one for âTV offâ - both with the same code of course. Iâve setup
SmartThings with Beckyâs Device Handler with external IP:7474 and default
Admin|Bridge credentials. Also created a device called âTVâ. It tests okay
because the SmartThings app responds on the Android with each on|off from
the Simulator. So Iâm happy that the calls are making to the Android box
which is an old Samsung Tab3 running 4.4.2. Iâve enabled the Alexa skill
and is listed as SmartThings device âTVâ. If I say command 'AlexaâŠTV ONâ
I get the response âOkayâ back from Alexa - and the SmartThings app updates on the Android.
Iâve checked my Wifi and have all devices running on 2.4Ghz.
So Iâve reached the conclusion that the RM Bridge on Android isnt
responding to the Smartthings code. I just cannot figure what the problem
is though. The SmartThings simulator doesnt return any errors. I added your
version of RM Bridge Switch LAN device handler, as this has debug messages,
and âpublished for meâ. It reads as (Iâve removed the IP):-
DEVICE LABEL - TV
Running REST API Command http://[my external IP]:7474/code/TV%20on
TV on()
I think that just about everything Iâve done - any help would be awesome!
One more thought - the SmartThings devices donât have Hub or Location - hopefully not essential?
cheers
I noticed an extra RM Bridge Switch LAN on ST Devices - not sure if this is relevant?
Anybody know why it is listing 2 - are they different? Kinda suggests an issue.
cheers
AHHHHHH! - using wrong device handler - should have been using Broadlink-RM-SmartThings-Alexa/RM Bridge Switch Cloud
DOH!
Iâm now in business - thanks for you help
Great, I was about to say the same thing . You need to use cloud version for external ip.
Seems there was some work going on - making sure all âcloudâ devicesâŠ
Hi - very embarrassing - I was using the wrong device handler! I was using LAN instead of Cloud version. Everything is working now and having great fun adding TV functionality.
One question - âTV on|offâ and âTV Guide on|offâ work well. Any suggestions for up|down or PgUp|PgDn? The voice command âTurn up onâ doesnât really track very well. Should I be using a different controller?
Cheers
Hi, newbie here after some help please. Ive followed the guide (using RM Bridge route), but Iâm getting this error when I hit create on the device handler setup???
Org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script14909174766202136987338.groovy: 39: expecting â}â, found â,â @ line 39, column 20. 38 state âoffâ, label: â${currentValue}â, action: âswitch.onâ, icon: âst.switches.switch.offâ, backgroundColor: â#ffffffâ ^ 1 error
Any ideas? thanks
There is no direct way to turn up / down volume.
I did it round about way via dummy dimmer and using its previous and current values to determine if I want volume up or down and how much.
I got volume up and down learned to RM bridge then I wrote simulated dimmer named âhome theaterâ . then I created smart app to use dimmer as volume control. If I say âturn up home theaterâ, it does the work done. Let me know if u want to use code, I will share.
Hi - its errored on missing closing bracket - try copying & pasting the script again and make sure you have all of it.
