'Brithgen when open' app seems to craash wemo bulbs
Hi all
Just after a code review if possible.
I wrote an app when I got my smart things device and its job was simple…
  1. On door open, brighten up the dim value a light
  2. On door close, lower the dim value of the light
  3. When somebody returns, brighten up the dim value of a light
The dim values were hard set and has worked reliably for a long time. It would only change the values if the light was on.
I decided to expand upon the original code because I had a set of lights which only 1 would be on (out of 6) but in the event of a door opening, it would brighten the lot up and then return to the original settings, assuming one of the lights in the group was already on, and then off/dim to the original status on close, I wanted to be as flexible as possible so I could rotate which bulk head light was on to even the ‘wear’ on the bulbs. Also, I can use the below to group bulbs together that are at different low dim values in 1 smartapp rather than multiple ones.
So the below update is the outcome.
It seems to work, and I think I have captured most of the bugs over time, however when I swap out the old app for this one, it seems to increase the likelihood of my wemo bulbs to crash. I am not quite sure why, only thing I can think of is I am requesting more refreshes of the bulbs to update the app, and to ensure that the data I am storing between door opening and closing is up to date.
I am also not sure if the problem could be down to a firmware issue of the wemo bulbs. I have recently spent some time resetting, updating via a wemo hub and re-adding back to smart things, but have not re-tried the below script yet.
Any pointers?
 *  App Name:   [Scene Machine] Brighten Outside Lights 2
 * Use License: Non-Profit Open Software License version 3.0 (NPOSL-3.0)
 *              http://opensource.org/licenses/NPOSL-3.0
// Automatically generated. Make future change here.
definition(
    name: "Brighten When Open 2",
    namespace: "",
    author: "Stephen Harding",
    description: "Controls multiple dim value of multiple bulbs when doors open/close/presence.",
    category: "My Apps",
    iconUrl: "http://cdn.device-icons.smartthings.com/Lighting/light11-icn.png",
    iconX2Url: "http://cdn.device-icons.smartthings.com/Lighting/light11-icn@2x.png"
preferences {
	section("Sensors"){
		input(name: "contact1", type: "capability.contactSensor", multiple: true, title: "Which Door?")
		input(name: "switches", type: "capability.switch", multiple: true, title: "Which Dimmers/Lights?")
        input(name: "people", type: "capability.presenceSensor", multiple: true, title: "Which people?", required: false)
	section("Brightness Settings"){
		input(name: "numOpenDimVal", type: "number", title: "Open Dim Value%", required: true)
		input(name: "numClosedDimVal", type: "number", title: "Closed dim value", required: true)
	section("Others") {
		input(name: "numMintoDim", type: "number", title: "Minutes after door closed to dim", required: true)
		input(name: "boolReturnDimVal", type: "enum", title: "Return to previous dim value?", options: ["Yes","No"], required: true)
        input(name: "boolSwitchOnOffLights", type: "enum", title: "Switch on lights which are off on open?", options: ["Yes","No"], required: true)
def installed() {
//	log.debug "Installed with settings: ${settings}"
	subscribe(contact1, "contact.open", contactOpenHandler)
	subscribe(contact1, "contact.closed", contactClosedHandler)
    subscribe(people, "presence", presenceHandler)
	//subscribe(knockSensor, "acceleration.active", doorknockHandler)
def updated() {
//	log.debug "Updated with settings: ${settings}"
	unsubscribe()
def presenceHandler(evt) {
	if("present" == evt.value) {
    	//When somebody arrives, welcome them with brighter lights!
        //I will assume they will go through a door so the closed routines should run later.
        state.PresenceDetected = "True"
        OpenRoutine()
def contactOpenHandler(evt) {
	log.info("Open Door detected....")
	OpenRoutine()
def contactClosedHandler(evt) {
    log.info("Closed Door detected....")
	def AddMinutes = numMintoDim * 60 //Convert to seconds
    def nowdate = new Date()
	log.info("Delay close routine for: $AddMinutes seconds")
    //Because of the delay, there could be another open event within the time frame.  To prevent
    //sucking out the previous dim values before they have had had a chance to be re-set, set a flag
    //and use it to prevent the old settings being wiped out with a new open event!
    state.ClosedRunning = "True"
    runIn(AddMinutes, ClosedRoutine)
    //runIn(15, ClosedRoutine)
def ClosedRoutine(){
	def switchState = ""
	def dimmerValue = ""
	def ClosedDimValue = numClosedDimVal
	def ReturntoPrevDim = boolReturnDimVal
    def cnt = 0
    def DeviceName
    def NewDimLevel
    state.PresenceDetected = "False" //Reset Presence
	//log.info("BWO: Closed dim Value (before if...) $ClosedDimValue")
	if(ClosedDimValue > 100){
		ClosedDimValue = 100
	else if(ClosedDimValue < 0){
		ClosedDimValue = 0
	else{
		//ClosedDimValue = 11
	//log.info("Closed dim Value (after if) $ClosedDimValue")
	log.info("Return to previous device dim value? $RerturntoPrevDim")
    cnt = 0
	for(mySwitch in switches) {
		switchState = mySwitch.latestValue("switch")
		dimmerValue = mySwitch.latestValue("level")
        DeviceName = mySwitch.displayName
        log.info "Bulb $cnt: $DeviceName: Current Switch State: 	$switchState /	Dim Value: $dimmerValue"
        log.info "Bulb $cnt: $DeviceName: Previous Switch State: ${state."BulbState_$cnt"} / 	Dim Value: ${state."BulbLevel_$cnt"}"
		if(switchState == "off"){
			log.info "Bulb $cnt: Switch is already off!"
		else{
            if("${state."BulbState_$cnt"}" == "off"){
            	log.info "Bulb $cnt: Previous State was off, so switch it off!"
            	mySwitch.off()
            else{
                if(ReturntoPrevDim == "Yes"){
                	log.info "Bulb $cnt: Previous State was on and app is set to go back to devices previous dim value!"
                	NewDimLevel = "${state."BulbLevel_$cnt"}".toInteger()
                    mySwitch.setLevel(NewDimLevel)
                else{
                	log.info "Bulb $cnt: Previous State was on and app is set to go back to set dim value!"
	                mySwitch.setLevel(ClosedDimValue)
		log.info ""
        cnt++  //Next!
	runIn(10,RefreshStatus) //Refresh bulb status after 5 seconds to allow the light to dim fully.
    state.ClosedRunning = "False"
def OpenRoutine(){
	def OpenDimValue = numOpenDimVal
    def SwitchOnOffLights = boolSwitchOnOffLights
	def cnt = 0
	def DeviceName
    //Set default global on value....
    state.GlobalOnStatus = "off"
	//Fix new dim value if its outside sensible values
	if(OpenDimValue > 100){
		OpenDimValue = 100
	else if(OpenDimValue < 0){
		OpenDimValue = 0
	else{
		//OpenDimValue = 100
	log.info("Open Dim Value: $OpenDimValue")
    	mySwitch.refresh()
    	// Get the original light status....
        //Store some data!
        if("${state.ClosedRunning}" == "True"){
			log.info "Bulb $cnt: $DeviceName: Closed Routine apppears to be running, do not store new values to preserve correct dim values"
        else if("${state.PresenceDetected}" == "True"){
        	log.info "Bulb $cnt: $DeviceName: Presence routine recently ran, do not store new values to preserve correct dim values"
       	else{
            state."BulbState_$cnt" = switchState
        	state."BulbLevel_$cnt" = dimmerValue.toInteger()
			if(switchState == "on"){
				state.GlobalOnStatus = "on"
		cnt++ //Next!
	cnt = 0
    	log.info "Bulb $cnt: $DeviceName: Bulb Status: ${state."BulbState_$cnt"} / Dim Value: ${state."BulbLevel_$cnt"} / Global On: ${state.GlobalOnStatus} / Closed Routine Status: ${state.ClosedRunning} / Presense routine Status: ${state.PresenceDetected} / Switch on off: $SwitchOnOffLights"
		// Done collecting data, lets move forward with changing the brightness....
		if(switchState == "off") {
        	if("${state.GlobalOnStatus}" == "on" && SwitchOnOffLights == "Yes") {
            	log.info "Bulb $cnt: $DeviceName: Switch is off, but another in the group is on... so turn it on!"
                mySwitch.on()
                mySwitch.refresh()
                mySwitch.setLevel(OpenDimValue)
            else{
            	log.info "Bulb $cnt: $DeviceName: Switch is off, and leave off as no other lights are on within the group"
		else{
			log.info "Bulb $cnt: $DeviceName: Switch is on, set new dim value"
		log.info ""
		cnt++ //Next!
	runIn(10,RefreshStatus) //Refresh bulb status to allow the light to dim fully.
def RefreshStatus() {
	//Routine to refresh light status.
	//log.info "BWO: Refreshing light status"
    for(myCounter in switches) {
    	myCounter.refresh()
    log.info "Done Refreshing light status"
when the light is off it does not turn on and then bring to the brightness i want. it won’t turn on at all. otherwise it works really great. I am hoping you will be able to fix as this app is awesome.
