I have been using this customized DH from smartThings generic Z-wave for my Brights. I added the fingerprint from the Brightswitches to identify the Brights when they are added to smartthings and it also has my own custom code for a 10% dim up and down button on the main on/off tile. If you want just the normal generic dim you can take the fingerprint line and add it to the Smartthings’ generic z-wave dim, or just change the device type from whatever is installed to generic zwave dimmer switch.
*Modified by spinn360 to add control buttons on manin tile to adjust dim.
* and to add fingerprint for Brightswitches when they connect to SmartThings
*Originally authored by SmartThings
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Z-Wave Dimmer Switch Generic2", namespace: "spinn360", author: "spinn360", ocfDeviceType: "oic.d.light", minHubCoreVersion: '000.019.00012', executeCommandsLocally: true) {
capability "Switch Level"
capability "Actuator"
capability "Health Check"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Light"
command "levelUp"
command "levelDown"
command "randomizeLevel"
fingerprint inClusters: "0x26", deviceJoinName: "Z-Wave Dimmer"
fingerprint mfr:"001D", prod:"1902", deviceJoinName: "Z-Wave Dimmer"
fingerprint mfr:"001D", prod:"1B03", model:"0334", deviceJoinName: "Leviton Universal Dimmer"
fingerprint mfr:"011A", prod:"0102", model:"0201", deviceJoinName: "Enerwave In-Wall Dimmer"
fingerprint mfr:"001D", prod:"1001", model:"0334", deviceJoinName: "Leviton 3-Speed Fan Controller"
fingerprint mfr:"001D", prod:"0602", model:"0334", deviceJoinName: "Leviton Magnetic Low Voltage Dimmer"
fingerprint mfr:"001D", prod:"0401", model:"0334", deviceJoinName: "Leviton 600W Incandescent Dimmer"
fingerprint mfr:"0111", prod:"8200", model:"0200", deviceJoinName: "Remotec Technology Plug-In Dimmer"
fingerprint mfr:"1104", prod:"001D", model:"0501", deviceJoinName: "Leviton 1000W Incandescant Dimmer"
fingerprint mfr:"0039", prod:"5044", model:"3033", deviceJoinName: "Honeywell Z-Wave Plug-in Dimmer (Dual Outlet)"
fingerprint mfr:"0039", prod:"5044", model:"3038", deviceJoinName: "Honeywell Z-Wave Plug-in Dimmer"
fingerprint mfr:"0039", prod:"4944", model:"3038", deviceJoinName: "Honeywell Z-Wave In-Wall Smart Dimmer"
fingerprint mfr:"0039", prod:"4944", model:"3130", deviceJoinName: "Honeywell Z-Wave In-Wall Smart Toggle Dimmer"
fingerprint mfr:"0063", prod:"4944", model:"3034", deviceJoinName: "GE In-Wall Smart Fan Control"
fingerprint mfr:"0063", prod:"4944", model:"3131", deviceJoinName: "GE In-Wall Smart Fan Control"
fingerprint mfr:"0039", prod:"4944", model:"3131", deviceJoinName: "Honeywell Z-Wave Plus In-Wall Fan Speed Control"
fingerprint mfr:"0196", prod:"00B7", model:"0097", deviceJoinName: "Brightswitch"
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
status "09%": "command: 2003, payload: 09"
status "10%": "command: 2003, payload: 0A"
status "33%": "command: 2003, payload: 21"
status "66%": "command: 2003, payload: 42"
status "99%": "command: 2003, payload: 63"
// reply messages
reply "2001FF,delay 5000,2602": "command: 2603, payload: FF"
reply "200100,delay 5000,2602": "command: 2603, payload: 00"
reply "200119,delay 5000,2602": "command: 2603, payload: 19"
reply "200132,delay 5000,2602": "command: 2603, payload: 32"
reply "20014B,delay 5000,2602": "command: 2603, payload: 4B"
reply "200163,delay 5000,2602": "command: 2603, payload: 63"
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute("device.level", key: "VALUE_CONTROL") {
attributeState "VALUE_UP", action: "levelUp"
attributeState "VALUE_DOWN", action: "levelDown"
/** attributeState "level", label:'${currentValue}', defaultState: true, backgroundColors:[
* [value: 0, color: "#ff0000"],
* [value: 20, color: "#ffff00"],
* [value: 40, color: "#00ff00"],
* [value: 60, color: "#00ffff"],
* [value: 80, color: "#0000ff"],
* [value: 100, color: "#ff00ff"]
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel"
// controlTile("levelSliderControl", "device.level", "slider", height: 2, width: 2) {
// state "level", action:"switch level.setLevel", label:'${currentValue} %', unit:"%", backgroundColor:"#ffffff"
standardTile("refresh", "device.switch", width: 6, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
// height: 1, width: 2) {
main(["switch"])
details(["switch", "sliderTile", "refresh"])
def installed(){
// Device-Watch simply pings if no device events received for 32min(checkInterval)
sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
response(refresh())
def updated(){
def getCommandClassVersions() {
0x20: 1, // Basic
0x26: 1, // SwitchMultilevel
0x56: 1, // Crc16Encap
0x70: 1, // Configuration
def result = null
if (description != "updated") {
log.debug "parse() >> zwave.parse($description)"
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result = zwaveEvent(cmd)
if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
result = [result, response(zwave.basicV1.basicGet())]
log.debug "Was hailed: requesting state update"
} else {
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelSet cmd) {
dimmerEvents(cmd)
private dimmerEvents(physicalgraph.zwave.Command cmd) {
def value = (cmd.value ? "on" : "off")
def result = [createEvent(name: "switch", value: value)]
if (cmd.value && cmd.value <= 100) {
result << createEvent(name: "level", value: cmd.value, unit: "%")
return result
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug "ConfigurationReport $cmd"
def value = "when off"
if (cmd.configurationValue[0] == 1) {value = "when on"}
if (cmd.configurationValue[0] == 2) {value = "never"}
createEvent([name: "indicatorStatus", value: value])
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
createEvent([name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false])
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.debug "manufacturerId: ${cmd.manufacturerId}"
log.debug "manufacturerName: ${cmd.manufacturerName}"
log.debug "productId: ${cmd.productId}"
log.debug "productTypeId: ${cmd.productTypeId}"
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue("MSR", msr)
updateDataValue("manufacturer", cmd.manufacturerName)
createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
[createEvent(name:"switch", value:"on"), response(zwave.switchMultilevelV1.switchMultilevelGet().format())]
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def versions = commandClassVersions
def version = versions[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
if (encapsulatedCommand) {
zwaveEvent(encapsulatedCommand)
// Handles all Z-Wave commands we aren't interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
],5000)
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
],5000)
def setLevel(value) {
log.debug "setLevel >> value: $value"
def valueaux = value as Integer
def level = Math.max(Math.min(valueaux, 99), 0)
if (level > 0) {
sendEvent(name: "switch", value: "on")
} else {
sendEvent(name: "switch", value: "off")
sendEvent(name: "level", value: level, unit: "%")
delayBetween ([zwave.basicV1.basicSet(value: level).format(), zwave.switchMultilevelV1.switchMultilevelGet().format()], 5000)
def setLevel(value, duration) {
log.debug "setLevel >> value: $value, duration: $duration"
def dimmingDuration = duration < 128 ? duration : 128 + Math.round(duration / 60)
def getStatusDelay = duration < 128 ? (duration*1000)+2000 : (Math.round(duration / 60)*60*1000)+2000
delayBetween ([zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: dimmingDuration).format(),
zwave.switchMultilevelV1.switchMultilevelGet().format()], getStatusDelay)
def poll() {
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
refresh()
def refresh() {
log.debug "refresh() is called"
def commands = []
commands << zwave.switchMultilevelV1.switchMultilevelGet().format()
if (getDataValue("MSR") == null) {
commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
delayBetween(commands,100)
def invertSwitch(invert=true) {
if (invert) {
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
else {
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
def levelUp() {
def level = device.latestValue("level") as Integer ?: 0
if (level < 101) {
level = level + 10
setLevel(level)
def levelDown() {
if (level > 0) {
level = level - 10
setLevel(level)
Talked with the Brightswitch team they have the motion sensor DH and Service manager built to add Brightswtich motion detection on SmartThings… I don’t have the code though. I know I couldn’t figure out smartthings lan device types with smartmanager after reading documentation and re-reading documentation, over and over and over again, so I am glad they were able to figure it out. I swear SmartThings is documented to prevent adding new devices… IMO.
Anyways hope this helps anyone with their Brightswitch.
