Bond/Smartthings - Ceiling fan with two lights
I have a ceiling fan that has a “top” light and a “bottom” light. On the fan control, they are controlled using two different buttons. Bond has no problem distinguishing between the two. However, when I pull the fan into Smartthings, ST only recognizes the Top light (I assume because it’s listed first in the Bond app.
Is there a way to get ST to pull in both lights and maybe even combine them so they turn on and off with the same command?
