A while back I went through the effort to load the BI Fusion Smart App into SmartThings. Unfortunately I don’t have a lot of time to play with it and configure the devices. But I was wondering if BI Fusion would work with the new version Blue Iris 5?
Also with ActionTiles? I would assume ActionTiles would not have an issue bc it’s standard access.
I upgraded to BI 5 and the BI ST App and setup continued to work without any changes. (I use the app to trigger recordings if a door sensor opens when I’m away e.g and to set the BI Mode (according to ST’s modes.)
tgauchat
5
ActionTiles should work if Blue Iris still offers embeddable MJPEG streams or JPEG snapshots.
Authentication parameters in the form: user:password@address are blocked by Chrome and Android Webview (Fully, etc.), so you likely have to disable authentication in Blue Iris. This is reasonably safe within your NAT protected LAN.
