This Italian wall thermostat is European but seems to only work with the Quivicon Hub from Germany .
Any thoughts on a device handler ?
Technical l Manual is here : http://od.bitronvideo.eu/Documentation/Manuals/Smart%20Home/User%20Manuals/902010-32%20tech.pdf
I am not a programmer !
Simon Drew
Hi,
I’m using it with Hubitat (very similar to SmartThings) with a custom driver, but I’ve initially tried it with a Hubitat port of this driver and basics functions were fine: https://github.com/ckpt-martin/SmartThings/blob/master/eCozy/DeviceHandler/eCozy-ZigBee-Thermostat-DTH.groovy
An annoying problem is that it doesn’t report changes to the controller, so I had to force it sending updates every 2 minutes regardless changes.
