@rayzurbock Here is the error message when press the BigTalker-DEV-Parent in SmartApps under SmartThings
//949a68f1-a3a5-4c7f-bca2-50ea93bb32cd 上午11:21:10: error groovy.lang.MissingMethodException: No signature of method: script150699972445498625217.setAppVersion() is applicable for argument types: () values: [] @ line 26
//949a68f1-a3a5-4c7f-bca2-50ea93bb32cd 上午11:20:10: error groovy.lang.MissingMethodException: No signature of method: script150700017135698625217.setAppVersion() is applicable for argument types: () values: [] @ line 26
Good idea, Perhaps I should create and publish a few samples, eventually.
For those that do not know (which is nobody until this post):
I have some Morgan Freeman sound-alikes published (much thanks to @EasyE (@nelemansc )) that you can use with musicPlayer mode and the new %mp3(https://xxxxxx.xxxx)% phrase token.
replace https://xxxxx.xxxx in %mp3()% with:
%mp3(https://lowrance.cc/ST/audio/mf/)% and append the following after …audio/mf/(if you have trouble, replace spaces with %20)
back door has been opened.mp3
basement door has been opened.mp3
cleaning supplies cabinet has been opened.mp3
front door has been opened.mp3
good morning.mp3
good night.mp3
liquor cabinet has been opened.mp3
patio door has been opened.mp3
searching for car keys.mp3
setting the mood.mp3
starting movie mode.mp3
starting party mode.mp3
starting romance mode.mp3
turning off all the lights.mp3
turning off the air conditioner.mp3
turning off the bar lights.mp3
turning off the chandelier.mp3
turning off the family room lights.mp3
turning off the hallway lights.mp3
turning off the kitchen light.mp3
turning off the light.mp3
turning off the lights.mp3
turning off the mood lights.mp3
turning off the tv.mp3
turning on all the lights.mp3
turning on the air conditioner.mp3
turning on the bar lights.mp3
turning on the chandelier.mp3
turning on the family room lights.mp3
turning on the hallway lights.mp3
turning on the humidifier.mp3
turning on the kitchen light.mp3
turning on the light.mp3
turning on the lights.mp3
turning on the mood lights.mp3
turning on the tv.mp3
vacate the premesis.mp3
** Disclaimer: The voices portrayed are not the actor Morgan Freeman. They were freelanced by someone else. I didn’t create these nor commission their creation. I have been granted permission to host them for BigTalker by @EasyE (@nelemansc).
I would have thought that Amazon would have samples posted somewhere. I found a few of the foreign voices, but they were speaking in their native language. So hard to determine which would be the best.
That is by design. I am only exposing the en-us (US English) , en-gb (UK English) and es-us (Spanish) voices. SmartThings is only supported in these markets.
I highly recommend using Update from Repo twice. Once with just the parent app checked as well as publish. The second time with just the child app checked and publish NOT checked.
The voice option was just added to the 2.0 development version last night (see this post, link).
See the GitHub/Raw Code links 2 posts up.
If you are coming from BigTalker 1.1.12, don’t overwrite your old code. Instead you need to start from scratch with the 2.0 version. Launch BigTalker and scroll all the way down to the bottom, just above “Remove” you should see the version number. See this post for more info on moving to the dev version (link).
Yes, that’s the reason. Voice changing using this method only works if you are in musicPlayer mode.
The voice used when in speechSythesis mode is handled by the device (in this case the Android TTS engine on the device that you are using LANNouncer). There is no way for BigTalker or SmartThings to change the voice used on these devices.
When in musicPlayer mode (which doesn’t support LANNouncer), the text is sent through SmartThings API’s which utilize Amazon Polly TTS service and returns an MP3 URL that is then played. When sending the text we are able to request a specific voice that is supported by Amazon Polly.
Got it … found it on code too … I should look at it first before asking but many thanks to you and others … I guess I have to buy a cheap speakers instead of LanNouncer
> if (state.speechDeviceType == "capability.musicPlayer") {
