BigTalker 2.0 first Alpha released.
Looking for feedback and usage/test results.
Alpha/Beta version note: Please only install if you are willing to install a likely buggy SmartApp and assist with testing and development. You need to know how to view/copy/paste live logging data into a PM. I do test on my own system before publishing, but I don’t test everything. I also don’t release development versions until I believe they are mostly operational and I need feedback and help with further testing.
Note there are now two apps from the repository to install.
The Parent needs to be installed and published.
The Child needs to be installed, not published (it will not hurt if it is published, but may cause confusion as it will show up in your SmartApps list but all configuration must be done through the Parent app which creates the child apps.
This version should allow you to have unlimited schedules, unlimited event groups (3 per child app, but unlimited in number of child apps).
It also starts the implementation of personality (primarily only on light switch on/off events at this time) to phrases if you choose. It will add personality to the beginning and/or ending of your selected phrase. The personality is chosen based on the device name (ie: kitchen light where light is the keyword) and change (on/off). There are also some generic personality phrases thrown in to mix things up. Personality can be enabled/disabled on the Configure Defaults page.
If you have requested a feature in the past and do not see it in this version, please note, the Parent/Child app was #1 priority before adding other major features. I plan to review your requests and add more (including more personality) before the actual 2.0 release. Your requests have been heard!
This is very very alpha and very limited in testing. If you don’t mind some possibly buggy code give it a shot and PM me some feedback on bugs and such. How’s the configuration flow, etc… ?
There are two options for install, GitHub or Raw code:
GitHub
- GitHub Integration Settings:
Owner: rayzurbock
Branch: development
- I highly recommend using Update from Repo twice. Once with just the parent app checked as well as publish. The second time with just the child app checked and publish NOT checked.
Raw Code
- Raw code for the parent app (must be published):
- Raw code for the child app (must be saved, publish not needed/desired):
UPDATE: 11:02PM CST - Parent/Child 2.0.a2 released
UPDATE: 4/6/2017 12:45PM CST - Updated Parent/Child Raw Code links
