BFT v1.9 Tool By BossV Setup for Android Devices Repair, Flashing & FRP [2027]
BFT Tool (Best Flash Tool) is a Windows utility aimed primarily at mobile technicians. Depending on the device, chipset, Android version, and security level, it can provide several software-servicing functions from one interface. It provides a centralized environment for working with supported smartphones and can simplify routine servicing tasks such as device detection, software management, and other technical procedures. Its practical interface makes it suitable for repair technicians and experienced users who regularly handle mobile device maintenance.
Download:backhand_index_pointing_left:
Before using BFT Tool, users should verify compatibility with their specific device and software version. It is also recommended to back up important data and use the correct firmware, drivers, and configuration files before performing servicing operations. For safer results, always use a legitimate version from a trusted source and follow the appropriate technical documentation.
Typical areas include:
  • :mobile_phone: Device information reading
  • :wrench: Android software servicing
  • :floppy_disk: Firmware/ROM flashing
  • :counterclockwise_arrows_button: Factory-reset-related operations
  • :locked_with_key: Certain lock/FRP servicing functions on supported devices
  • :hammer_and_wrench: Diagnostics and troubleshooting
  • :gear: Boot/connection operations
  • :satellite_antenna: Chipset-specific servicing
The exact functions are model- and security-level dependent; a feature working on one phone does not mean it will work on every phone. BetterTouchTool Community+1
Chipset support
Current references commonly associate BFT Tool with:
Platform Typical role
MediaTek (MTK) BROM/preloader-based servicing, flashing and supported repairs
Qualcomm Qualcomm device servicing and firmware-related operations
Unisoc / SPD Supported flashing/servicing operations
Other devices Depends on the particular release/model
For example, a recent repair report documents BFT Tool communicating with a MediaTek Tecno KE5K through BROM for an FRP service operation. Gadgets
Common workflow
A technician will generally:
  1. Install BFT Tool on Windows.
  2. Install the appropriate USB/VCOM/Qualcomm/SPD drivers.
  3. Open the required BFT module.
  4. Select the phone brand/model or appropriate operation.
  5. Connect the phone in the required boot/USB mode.
  6. Allow BFT to identify the device.
  7. Read device information and verify the chipset/security state.
  8. Select the appropriate service operation.
  9. Execute the operation.
  10. Check the log for success/failure.
Important: flashing or resetting the wrong partition/firmware can brick a device or cause data loss, so firmware must match the exact model/variant.
BFT vs ordinary flashing tools
The main advantage is that BFT attempts to put several servicing functions into one Windows application rather than requiring a separate utility for every chipset or task.
For example:
  • MTK-specific tools → primarily MediaTek
  • Qualcomm-specific tools → primarily Qualcomm
  • SPD tools → primarily Unisoc
  • BFT → attempts to provide a broader servicing interface across supported platforms
However, a specialized tool can still be better for a particular phone or operation.
BFT Tool versions
Search results currently frequently mention BFT Tool v1.8, but there is a significant security issue here: a September 2026 report warns that fake/unofficial BFT v1.8 installers are circulating, including a suspicious BFTSetup1.8.exe. Gadgets
So I would not recommend downloading a random “BFT Tool v1.8” setup from a third-party page.
Security precautions
Before installing any BFT package:
  • Verify the source.
  • Scan the executable with reputable antivirus/malware scanners.
  • Don’t disable Windows Defender simply because the installer requests it.
  • Don’t use modified/cracked builds when you can avoid them.
  • Back up important phone data.
  • Confirm the exact phone model/variant before flashing.
  • Don’t flash firmware merely because the chipset is the same.
What BFT can and cannot do
Can potentially do:
  • Read phone information
  • Flash supported firmware
  • Perform supported reset/service operations
  • Work with certain MTK/Qualcomm/Unisoc devices
  • Assist with Android software troubleshooting
Cannot universally do:
  • Service every Android model
  • Bypass every modern security patch
  • Flash arbitrary firmware safely
  • Repair hardware faults
  • Guarantee FRP/lock operations on every security level
The actual capabilities depend heavily on phone model + chipset + Android version + security patch + boot mode + BFT version.
If by “BFT Tool” you mean the Android/mobile-repair BFT Tool, I can also give you a complete technician guide covering MTK, Qualcomm, Unisoc, FRP, flashing, drivers, errors, and safe procedures.
What model?
If it’s one of the h2 plugs, use this driver:
In general there’s no way to change the classification of a device. Which can be really annoying!
I own 9 Aqara leak sensors and 3 temperature sensors along with 1 plug in outlet. I initially tried to connect them (just the temperature sensors at the time) directly to SmartThings but they kept dropping offline. I ended up buying a Aqara huh and connecting to SmartThings via Matter-over-bridge.
You can, sort of. Open the “Lights” summary from the Dashboard, open the sole menu item “device selection”, and uncheck everything that isn’t actually a light. Then open the device page itself and pick a more suitable icon.
The same approach also lets you bring a smart outlet that actually controls a lamp into the “lights” category.
Two questions spring to mind:
  1. In what way are they categorised as lights? Each component of a device can have a category. One is the ‘manufacturer’ category set by the developer of the integration, and you may find more adventurous community developers in particular will allow the device profile to be manipulated to change this. The other is the ‘user’ category which can be set by the API. It used to be the case that changing the icon of a device might also change the user category of the main component, but that seemed to stop and those with more recently tweaked icons seem to me to have both categories the same.
  2. What is the change intended to achieve for you? It isn’t really clear what the categories do for you except influence the default icon used in the app. They are also used in determining eligibility for the various dashboard tiles, but I guess the app could indulge itself a bit with its custom device presentations based on them.
Well dang! How long has that been there! Useful if not 100% as you noted.
It let me add my Kasa outdoor Matter-over-Wi-Fi outlet that controls deck lights to the lights summary tile.
