Use caution when turning a virtual switch ON! It could result in an immediate GO TO / EXIT. The placement of the ON action is critical. It should be placed LAST in the action sequence! Otherwise the remainder of the actions will not be run. This happened to me regarding a Webcore piston turning ON a delayed Goodbye switch. As soon as I set the switch ON, the Goodbye automation was run…before the remaining piston commands could be executed. In my case, the Webcore “wait” command was never being run.
