[Beta] Zigbee Edge Driver compatible with Lidl, Ecosmart, Osram, SmartThings & Others
Hi Mariano.
You can add the switch 3 plug to the zigbee-multi-switch-Zemismart driver, this was not added yet.
The fingerprints is:
id: β€œ3A Smart / LXN3S2”
deviceLabel: 3A Smart 3 Switch
manufacturer: 3A Smart Home DE
model: LXN-3S27LX1.0
deviceProfileName: three-switch
Thank you.
Added to thid driver version
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ Zigbee Multi Switch Zemismart Mc     β”‚
β”‚ Version     β”‚ 2022-01-16T15:30:24.100704           β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
  - id: "3A Smart/LXN-3S27LX1.0"
    deviceLabel: 3A Smart 2 Switch
Hi Mariano.
I have a problem with the Innr plug. With your driver
Zigbee Switch Power Mc the power meter is multiplied by 1000 (this after updating the hub to version 41).
Can you also insert a system to reset the counters?
My friend, this driver was perfect, thanks again for the help!
As the libraries have changed, it is possible that they have fixed some and damaged others.
you can try to reinstall the device so that it is configured again with the values of the divisor and multiplier that the device returns. Let’s see if it fixes.
There is also a new stock driver in the Beta channel smartthings zigbee light switch that has many devices, I don’t know if yours will be
Hello,
I have not any power meter device to test.
I will see when see wath changes they have done on libraries
Hi Mariano,
I know that is not recommended to pair hue bulbs because the network can be messed up. But I just got 2 for buying echo devices, so I don’t think is worthy to buy the hue bridge.
Could an edge driver be developed?
Added to this version of driver
Tell me if works, please
β”‚ Name        β”‚ Zigbee Light Multifunction Mc        β”‚
β”‚ Version     β”‚ 2022-01-16T21:28:21.774767           β”‚
  - id: "Signify/LWA017"
    deviceLabel: Bulb LWA017
    manufacturer: Signify Netherlands B.V.
    model: LWA017
    deviceProfileName: switch-level
That was fast!!
It pairs correctly and the dimmer level works good as well. However, for the progressive ON/OFF, the dimmer level is increased/decreased 1% each 3 or 4 seconds, so it would take several minutes to finish.
On top of that, when progressive OFF is not selected, the light is progressively off anyway.
For the progressive on and off, check the time settings for on and off and what you have to do if you press the switch during the progressive on or off, it is a bit messy to coordinate at first
@Mariano_Colmenarejo Hi my friend, how are you? With the last change the vibration sensor looks great, it’s working very well, @Glauber_GD was also successful in the tests. Thanks a lot for the help. :+1:
I see. I don’t really need this functionality, but in case this is useful for anyone:
  • Progressive ON active: the light switch on to the last dimmer value and inmediatly goes to the 1% value and start increasing according to configuration
This function was intended to replace the gentle wake up smart app.
but can also be used for other things
I have been using it daily in a lamp to turn on progressively at sunset, from 40% to 80% in 15 minutes and it always does it perfectly.
I don’t know what values you use to see what can happen in your lamp.
the first thing the driver does when on is pressed or receives an on command and progressive on is activated is to set the initial level to the initial value in preferences
@Paul_Oliver
I’ve moved this answer to this thread.
Hello @Paul_Oliver, thanks to the log sent I can try to do something.
I have seen this driver receive the normal messages of false = off and true = on and others duplicate messages false = 0 and true = 1 , which are mixed with the normal ones.
This causes changes of state that are sometimes contradictory since duplicate messages arrive followed by or mixed with different values, which produce the emission of events that do not correspond to the real state of the device.
Without knowing why this happens, I have made some corrections in the driver to see what result they give.
With others switches only receive false =off and true = on messages.
With the modification they also work well to see what happens.
β”‚ Name        β”‚ Zigbee Switch Mc                     β”‚
β”‚ Version     β”‚ 2022-01-17T11:31:07.881443           β”‚
Now I got it, my bad.
Works great, the ghost activations are gone!
Thanks a lot.
The 2022-01-17 version of your Zigbee Switch Mc Edge driver seems to have solved the problems with the Sonoff ZBMINI relay. Everything seem to be working as expected.
I will keep a watch on this and let you know if I see any problems.
Again Thank You for developing these Drivers and debugging them when there are problems.
If you use the actions of the automations you have the option to reset the total energy consumption.
It is the default option of the energyMeter capability presentation
I don’t know why the default presentation doesn’t show the ReserEnergy command in the details view, since in the presentation of the energyMeter capabiliy it is
@nayelyz
It has a solution this stock presentation of ResetEnergy command
Hi,
thank you very much for your great work. I am using the driver β€œTemp and Humidity Sensor MC” for a Sonoff SNZB-02. Everything is reported correctly within the details view of the device, but there is no temperature shown on the device tile.
Is this the expected behaviour or should the temperature show up on the device tile?
Sorry I made a mistake publising the latest version.
It is already fixed in this version, it should be fixed only when the new version is updated
β”‚ Name        β”‚ Zigbee Temp Humidity Sensor Mc       β”‚
β”‚ Version     β”‚ 2022-01-19T14:09:17.784994           β”‚
Hello my friend, how are you? Could you add this motion sensor please?
sensor_de_movimento
