second end point cant be controlled
what the options in your zemisamart controlller that can be added thru the ST app on iphone
Do you see a cloud?
Ignore to turn on or off?
It does not update the status in the app when it is activated or deactivated in the device?
This device was added a long time ago, I remember that at first it did not paired with driver.
It seems that now it pairs well?
Do you want to try the other multi switch driver or have you already tried it?
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Multi Switch Mc β
β Version β 2022-01-08T15:37:21.060165 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "FeiBit/ZSW1HKJ2.5"
deviceLabel: FeiBit 2 Switch
manufacturer: Feibit Inc co.
model: FB56+ZSW1HKJ2.5
deviceProfileName: two-switch
Would it be possible to add a new IKEA color bulb?
Raw Description 01 0104 010D 01 0A 0000 0003 0004 0005 0006 0008 0300 0B05 1000 FC7C 01 0019
would it be posible to have an option to change default state?
Iβd like it to always come back to βonβ after power outtage
But the lack of the manufacturerβs hub means canβt check for such settings
manufacturer: _TYZB01_b1ngbmlm
model: TS0112
Do you think the manufacturer could be this βeZEXβ that appears in the βnameβ field?
Because searching online, I saw that this manufacturer really existsβ¦
I do not know why, the RGBW bulbs from ikea do not work the color.
If you want, I can add it and try it.
If it doesnβt work, tell me to remove it
It may be the name of the DTH when pairing.
I can put that manufacturer, but the problem is that the device has to respond with the manufacturerβs name and match the one written in the fingerprints file and thus assign it a profile.
He has let me put it blank, as null to see if it matches that way, if not I will put eZEX
- id: "E220-KR3N0Z0-HA"
deviceLabel: MultiPlug
manufacturer:
model: E220-KR3N0Z0-HA
deviceProfileName: three-outlet
β Name β Zigbee Multi Switch Zemismart Mc β
β Version β 2022-01-09T16:22:04.498441 β
I donβt know what value and in which cluster, attribute it is necessary to change the value of the different options.
If anyone knows, I could give a try.
Added to this driver version
β Name β Zigbee Light Multifunction Mc β
β Version β 2022-01-09T17:20:12.477745 β
- id: "IKEA/E27 CWS 806lm"
deviceLabel: IKEA E27 Bulb
manufacturer: IKEA of Sweden
model: TRADFRI bulb E27 CWS 806lm
deviceProfileName: rgbw-level-colortemp-2700-6500
Will try the driver and will tell you if it works.
Works like a charm
@Andy11, @Mariano_Colmenarejo
This was one of the devices that added spaces into the fingerprint values, the team mentioned this is already fixed, so now the driver should include the fingerprint normally (without spaces) and the device should be paired correctly.
The driver was Zigbee Multi Switch Zemismart Mc
and these were the fingerprints reported:
- id: "FeiBit/ZSN08KJ2.3"
manufacturer: Feibit Inc co., LTD
model: FB56+ZSN08KJ2.3
Please, help us confirm this works correctly now.
Hello,
You mean this switch?
thanks
- id: "_TZ3000_yl3zuyaw/Switch"
deviceLabel: TZ3000 Switch
manufacturer: _TZ3000_yl3zuyaw
model: TS0001
deviceProfileName: single-switch
@Mariano_Colmenarejo, does the zigbee valve driver support this device?
Itβs a Leaksmart Water valve.
Sorry, I forgot to answer you
Does it work with battery or external power supply?
The driver that I use does not have battery information
The smartthings driver stock in the beta channel does have battery and power source information, but it does not have your fingerprints.
It has battery backup, but uses external power. Here is a screen shot from the DTH.
Iβm going to add it to the smartthings driver and test
β Name β Zigbee Valve ST Beta β
β Version β 2022-01-12T15:24:14.575482 β
- id : WAXMAN/Valve
deviceLabel : WAXMAN Valve
manufacturer: WAXMAN
model: leakSMART Water Valve v2.10
deviceProfileName: valve-battery-powerSource
I do not know if I have put the model correctly, it is better to send in text, to copy and paste
Does this help?
Data * zigbeeNodeType: SLEEPY_END_DEVICE
Glad to see this fix coming with firmware 0.41.x:
Both of this supposed to fix most of the issues with lights and plugs
