(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
I’m bothering you so much that I got lost in the posts… sorry. this one still missing @Mariano_Colmenarejo
Now it worked. Thanks
@niquini,
I already turned off the pc for today.
Tomorrow will be another day.
If any Edge drivers developer has enough time and a lot of patience to try with Zemismart/Tuya scene switches and remotes, please send me a PM. I am willing to help with information and testing.
Thanks for the ST Water Sensor driver. It seems to work well. Wet/dry and temperature show. Battery is not working but I am sure will be working in a couple hours like other battery operated devices.
Thanks again.
Only the icon that appears as switch.
But it’s alright
Tomorrw i will see
Data * zigbeeNodeType: ROUTER
  • application: 41
  • endpointId: 01
  • manufacturer: _TZ3000_oiymh3qu
  • model: TS011F
    Raw Description 01 0104 0009 01 04 0000 0004 0005 0006 02 0019 000A
appears as Thing
Would you be able to help me?
Good Morning @Mariano_Colmenarejo
all good?
one more oh…
Zemismart temperature and humidity sensor
  • application: 00
  • endpointId: 01
  • manufacturer: TUYATEC-jigsujrv
  • model: RH3052
  • zigbeeNodeType: SLEEPY_END_DEVICE
01 0104 0302 00 05 0000 0001 0003 0402 0405 03 0003 0402 0405
Has temperature, humidity and battery capacity
When I have a while I do it, I’ll let you know when it’s done
Thanks!!!
Added to this version driver Zigbee Temp Humidity Sensor Mc
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ Zigbee Temp Humidity Sensor Mc       β”‚
β”‚ Version     β”‚ 2021-12-21T15:16:28.379755           β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
  - id: "Zemismart/RH3052"
    deviceLabel: Zemismart RH3052
    model: RH3052
    deviceProfileName: temp-humid-battery
Added to Thermostat driver, in case you want to use Sensor as Thermostart device
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ Zigbee Temp Sensor with Thermostat Mc β”‚
β”‚ Version     β”‚ 2021-12-21T15:14:10.034083            β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
    model: RH3052
    deviceProfileName: temp-humid-therm-battery
This device does not work with the Switch driver since it does not have the cluster 0006 and uses the exclusive Tuya EF00 cluster
Added to this version of driver
β”‚ Name        β”‚ Zigbee Switch Mc                     β”‚
β”‚ Version     β”‚ 2021-12-21T15:17:22.042415           β”‚
  - id: "_TZ3000_oiymh3qu/TS011F"
    deviceLabel: LoraTap Switch
    model: TS011F
    deviceProfileName: single-switch
The siren icon is now fixed
Could you share a photo of the Sirena, to see what it is like?
Looks interesting
Portuguese
Hello @Mariano_Colmenarejo.
Could you please add this device:
It is a Tuya Thermometer
Data
  • application: 43
  • endpointId: 01
  • manufacturer: _TZ2000_a476raq2
  • model: TS0201
RAW
01 0104 0302 00 04 0000 0001 0402 0405 01 0019
@andre_petinga,
I’m going to be busy for a while, as soon as I can, I’ll do it and let you know
Ok. No problem.
And I need another one please:
IKEA Motion Sensor
Data
  • application: 20
  • endpointId: 01
  • manufacturer: IKEA of Sweden
  • model: TRADFRI motion sensor
RAW
01 0104 0850 01 07 0000 0001 0003 0009 0020 1000 FC7C 06 0003 0004 0006 0008 0019 1000
@Mariano_Colmenarejo a question for you: Drivers for Z-Wave devices. Can you make them to ?
Lora Tap Ok. Thanks.
