@Mariano_Colmenarejo when you create a device with more than one gang from the second onwards, switch2, switch3, etc. appears. Exiate some way to add something in that name to differentiate a switch2 from another switch2? I was following your advice to create virtuals but when mirroring the behavior appears more switch2, etc and I donβt know which is which.
@Mariano_Colmenarejo is it possible to add this Gledopto Plus GL-B-008ZS 12w lamp? Its color temperature ranges from 2000k-6500k as you can see in the link below
- application: 01
- endpointId: 0B
- manufacturer: GLEDOPTO
- model: GL-B-008ZS
- zigbeeNodeType: ROUTER
0B C05E 0210 02 07 0000 0003 0004 0005 0006 0008 0300 00
Nothing can be added.
Smartthings has already been told that this is a serious problem and they should give it a solution
ok. Thanks
@Mariano_Colmenarejo If Iβm being annoying about sending devices, let me know that Iβll stopβ¦
ZigBee RGBW Bulb
- application: 42
- endpointId: 01
- manufacturer: _TZ3000_i8l0nqdu
- model: TS0503B
01 0104 0102 01 08 0000 0003 0004 0005 0006 1000 0008 0300 02 0019 000A
Zemismart Contact Sensor (contact and battery)
- zigbeeNodeType: SLEEPY_END_DEVICE
- application: 4D
- endpointId: 01
- manufacturer: TUYATEC-n4qd0btb
- model: RH3001
01 0104 0402 00 04 0000 0001 0003 0500 01 0003
Added to this driver version
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Light Multifunction Mc β
β Version β 2021-12-19T23:32:51.599198 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "GLEDOPTO/GL-B-008ZS"
deviceLabel: GLEDOPTO GL-B-008ZS
model: GL-B-008ZS
deviceProfileName: rgbw-level-colortemp-2700-6500
the consumption of this now appears but I need to keep updating (pulling down). Is there anything that can be done to automatically refresh every second?
this temperature is 2000k-6500k
Only have one profile for rgbw 2700-6500k
the power is 10x of real power?
Send what you need.
Today Iβm going to sleep, tomorrow Iβll do what you send me
Thanks. Good night
I did not understand
the default report interval are those
classst.zigbee.defaults.powerMeter.ActivePowerConfiguration
cluster:number
ElectricalMeasurement ID 0x0B04
attribute:number
ActivePower ID 0x050B
minimum_interval:number
1 seconds
maximum_interval:number
3600 seconds (1 hour)
data_type:st.zigbee.data_types.Int16
the Int16 class
reportable_change:number
1 (some amount of W, dependent on multiplier and divisor)
Fixed it. Working perfectly now
added to this driver version
β Name β Zigbee Contact Mc β
β Version β 2021-12-20T10:04:35.942289 β
- id: "TUYATEC/n4qd0btb Open/Close Sensor"
deviceLabel: TUYATEC-n4qd0btb Open/Close Sensor
model: RH3001
deviceProfileName: contact-battery-profile
Added to this date version drive or later
β Version β 2021-12-20T10:11:15.05183 β
- id: "_TZ3000/TS0503B"
deviceLabel: RGBW TS0503B
model: TS0503B
There are times when the driver is not installed correctly, it takes longer to install than it seems in the app and sometimes the process is interrupted. Especially the first time a driver with custom capabilities is installed
Restarting the hub, clearing the cache if it is androind or reinstalling the driver is solved
