Pass the data of zemismartβs zigbee switch if you can to add
- application: 01
- endpointId: 01
- manufacturer: 3A Smart Home DE
- model: LXN59-1S7LX1.0
- zigbeeNodeType: ROUTER
01 0104 0100 01 05 0000 0003 0004 0005 0006 00
Zemismart has this outlet with consumption measurement. Is it possible to add it with these capabilities?
01 0104 0051 01 06 0000 0004 0005 0006 0702 0B04 02 0019 000A
Added to Zigbee Switch Mc (v4)
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Switch Mc β
β Version β 2021-12-19T17:44:32.72414 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "LXN59-1S7LX1.0/Switch"
deviceLabel: Zemismart Switch
deviceProfileName: single-switch
Added to Zigbee Switch Power M, with powerMeter profile
Check if the power measurement is correct or if need to apply a divisor
β Name β Zigbee Switch Power Mc β
β Version β 2021-12-19T17:50:56.459102 β
- id: "Zemismart/Plug"
deviceLabel: Zemismart Plug
manufacturer: _TZ3000_rdtixbnu
model: TS0121
deviceProfileName: switch-power-plug
I saw you posted a driver for 2 gang zemismart switch. I have this 3 gang that didnβt get the driver. Would it be possible to add it too?
01 C05E 0000 01 07 0000 0004 0003 0006 0005 1000 0008 01 0019
Have two or three components?
Two channels
This model is in Edge driver Zigbee Multi Switch Zemismart Mc and it will work fine
- id: "FeiBit/3-Switch"
deviceLabel: FeiBit 3 Switch
manufacturer: FeiBit
model: FNB56-ZSW03LX2.0
deviceProfileName: three-switch
Added to this version of Zigbee Multi Switch Mc.
If this driver not works fine, tell me. I can add to other Zigbee Multi Switch Zemismart Mc driver.
β Name β Zigbee Multi Switch Mc β
β Version β 2021-12-19T18:07:52.523234 β
- id: "Avatto/_TZ3000_bvrlqyj7"
deviceLabel: Avatto TZ3000 Switch
manufacturer: _TZ3000_bvrlqyj7
model: TS0002
deviceProfileName: two-switch
this outlet has power, total consumption and real-time measurement (w). Only power meter appeared and did not mark anything
this did not appear the updated driver
Iβm going to put it in the profile with energy measurement, but if the power meter doesnβt work, I donβt think the energy meter will work.
I have a TS0121 model from samotech that has the same clusters and I have not managed to get it to work in smartthings and Tuya app either
β Version β 2021-12-19T18:29:27.859585 β
model: TS0121
deviceProfileName: switch-power-energy-plug
I donβt know which driver you mean
thank you Mariano, Iβll test it and then Iβll give you feedback.
@niquini
This driver is in the channel and not need updated.
The model is in the driver long time ago
2021-12-05T11:01:49.327229 β
he didnβt recognize the 3 gang device
