I added it to the zigbee Motion and Zigbee Mc and SmartThings Multipurpose Sensor Mc controllers and during the following hours it has checked the version of the devices and the available one, adding the current firmware information to the device information.
They started to work when I changed back to latest versio All but Ikea plugs, they are only included in your latest driver, not in the old one. I canāt change their driver. I just pair them gain. Easiest way. I only have three of them.
Thanks for doing that so quickly ā tested ok with GL-B-007P and GLB-008P
This bulb definitely has a wider range ā 2000K to start. I have the handheld RF remote, and the driver correctly reads color temps below 2700K (which is an improvement over the legacy driver)!
Also, there seems to be an issue with the Last Step Level & Color increments ā the bulb definitely increments, and you can see the sliders adjust, but thereās no value in those boxes (they are blank)
It may have to do with the type of Hub, I did not disconnect any of them and all the zigbee devices that I have are with the new version of the driver. @Sakari, were also disconnected, I donāt know what kind of hub he has
No go ā still blank. And this was the first time I had loaded the driver.
Another possible clue: sometimes when I open the device, the control takes time to load/update ā the 3 Continuous Color Change controls below Circadian lighting is all missing ā if I go to History then back to Controls they appear.
@troy_owens@glenmm I had this issue this morning at 5:15 am. Many lights went on to maximum brightness, and some went down to minimum brightness (actually they were factory reseted by itself or driver). I was able to turn them all on and off by disconnecting and reconnecting power. Donāt delete any device, just re-added them using Scan Nearby, and that is how they got reconnected. I havenāt lost a single automation
