For me Lidl motion sensor driver didnt work. It constantly shows that the movement is active and that the battery is 0 percent.
It may not have been installed properly.
sometimes it happens
Uninstall it from the app, wait 10, 15 sec and add it again by searching nearby.
Wait about 30 sec to see if it connected well.
swipe down your finger on the device details screen to refresh the device
look in details giving driver, which driver has been installed
First, ST found the lidl motion sensor as a Generic switch (edge driver from @ygerlovin). When I changed the driver to zigbee motin sensor in the settings, the status was not updated and the battery showed 0%. I have now removed the driver from @ygerlovin and now the ST has found the device as a Lidl motion sensor and it works OK.
Thank you @Hafo for your update.
It is nice to see someone actually tried my driver.
It’s main purpose is to provide solution for Aqara switch. I will remove other generic fingerprints from this driver to reduce interference with other drivers.
Regards
I have three Lidl motion sensors in use. They won’t go offline but react slowly when no motion has been detected in a “long” time.
They must fall asleep,
This was already happening with the dth
New Edge Driver Zigbee Valve:
- Created from the default smartthings libraries
- Tested on the water or gas valve, without battery:
- Tuya zigbee 3.0
- manufacturer: _TYZB01_rifa0wlb
- model: TS0011
Drivers List UPDATED
Did exactly what you said and immediately it got detected as Zemismart KS–811-ZB. I am testing it on a 2-gang switch, the good news is the first gang works perfectly fine. However, it’s only working on the first gang. The 2nd gang do not appear on my list of devices. Do you think there will be a workaround on this? Thanks for you help.
So the data you sent me was from the single or double switch.?
This is important as it can cause problems for other users.
If they have different model IDs for the single and double, please send me the model of each.
If they have the same model number, only switch 1 will work with this driver.
If these models don’t use the identification of different endpoints for each switch, then I don’t know how to make them work with a Driver Edge.
I only have the 2-gang switch currently. So the one i sent is definitely a double switch.
i have moved back to DTH and saw that it was recognizing the 2nd switch as a child device. If that will help in any way.
Well, if you’re not sure on how to make a driver for this, then that is fine. Thanks for trying anyway.
Voucher,
It is already removed from the zigbee Switch driver to avoid problems.
Then I post a multiswitch driver for you to try
I will let you know when I am
Sounds great. thanks a lot.
I have published a Zigbee Multi Switch driver.
A device with two switches will appears in the details view.
Similar to how they appear in the Tuya app
Try it to see if it works.
With what you tell me, I’ll leave it or delete it
Hi Mariano.
You could add ID of this device in the Zigbee Multi Switch driver.
application: 01
endpointId: 0B
firmwareFullVersion: 00000001
firmwareImageType: 0
firmwareManufacturerCode: 4478
manufacturer: 3A Smart Home DE
model: LXN-2S27LX1.0
onOff: catchall
zigbeeNodeType: ROUTER
Raw Description 0B C05E 0000 01 07 0000 0004 0003 0006 0005 1000 0008 01 0019
Would you like to add some of Ikea bulbs to your driver?
Is it a double switch?
You have to tell me the profile,
switch and level
switch, level and color temperature
Manufacturer and model from IDE
I don’t have any to try!
Hi Mariano.
Yes, there is a double switch sold by Zemismart. It only has on / off function. Thank you very much for your help
This is the single switch, from the same series.
application: 01
endpointId: 0B
model: LXN-1S27LX1.0
onOff: catchall
This is the three in the same series
application: 01
endpointId: 01
manufacturer: FeiBit
model: FNB56-ZSW03LX2.0
onOff: catchall
Raw Description 01 C05E 0000 01 07 0000 0004 0003 0006 0005 1000 0008 01 0019
Both the switches were added.
Switch 1 (Main) works fine. I can control from the Smartthings app. But for Switch2, the moment switch it on (whether physically or via ST app), it switches on and off non stop.
Not sure if this is covered by the driver:
Also, when i try to assign an automation, it doesnt give me the option to create an automation for Main one only (bottom group on the screenshot). The first “Turn on” option is selected by default. I think it also makes sense if this can be labeled or something.
