They do not work with the zigbee contact driver, which uses stock libraries
2021-11-17T15:22:17.539121360+00:00 WARN Zigbee Contact Device does not support cluster 0x0001 not adding configured attribute
2021-11-17T15:22:17.542679527+00:00 WARN Zigbee Contact Device does not support cluster 0x0001 not adding monitored attribute
2021-11-17T15:22:17.547189652+00:00 WARN Zigbee Contact Device does not support cluster 0x0500 not adding configured attribute
2021-11-17T15:22:17.550549777+00:00 WARN Zigbee Contact Device does not support cluster 0x0500 not adding monitored attribute
You can use these specific xiaomi from @Zach_Varberg
I did have varzac driver installed (driver 2. on my driver list), but the sensor model attribute in the yaml file is different and I was not able to change to that driver;
Just try to re-add them. Don’t delete them. Start, Scanning, and put device in pairing mode. They will be added with the same name, and you will not loose any Automations. Pretty much they are just getting reconnected
OK both devices joined this time but still issues with each.
1 The Smartthings plug works as intended, however, the power consumption in watts is WAY higher (like around 10x) than the stock dth showed on each plug
2 Smartthings motion sensor (2015) still shows no temperature nor battery hours later Tried hub reboot and a rejoin as well.
Ecolink contact sensor stilll shows no battery hours later. Tried taking battery out for a while as well as a different battery
The problem of the temperature of the motion sensor was, that also the “h” in smartThings was missing in the subdriver. Copy and paste problems! Sorry
The problem with the motion sensor battery is that the drver did not have a “smartthings” subdriver to handle the battery by voltage. I have copied it from the multipurpose sensor driver and it is published with the changes with the version:
│ Name │ Zigbee Motion Sensor Mc
│ Version │ 2021-11-18T14: 26: 54.021422
The smatthings plug power calculation problem, I have no idea. The driver uses the Edge stock libraries for the powerMeter capability. Se lo podemos comentar a @nayelyz
For the ecolink contact sensor battery problem, I have not touched anything on that driver. If it worked before, it should work now. o Has it never worked?
Today I got smoke sensors (HEIMAN Zigbee 3.0 Fire alarm Smoke detector) that work well with the driver from @Mariano_Colmenarejo without any problems. I also did testing.
Only the icons do not show the true status and the base page does not say clear.
