Hi @gifa84
This device uses the EF00 cluster and is not compatible
Ask in this specific thread of the EF00 cluster
@Mariano_Colmenarejo,
Is there any chance we can get LQI and RSSI info for the zigbee window treatment driver? Thanks!
I will look at it.
Next week I wonât be able to do anything, remind me if you see that I donât answer the following week
Thanks! Will do!
Hi there,
Would be able to add the finger print to this sensor?
Centralite Micro Door and Window Sensor
I can give you the device ID, if you are able to.
Hi @3asmarthome
sorry, i forgot this.
I wonât be able to do it for a few days, I donât have access to the cli.
Thanks for your reply. It is fine to do it when you are convenient.
Thanks @Mariano, Successfully added all devices and made them working with google. Thanks a lot for your help all through the way. Much appreciated.
@Mariano_Colmenarejo Hi Mate,
I am still facing the same issue with contact sensor going to offline. Its happening for SONOFF and SAMOTECH contact sensors. Its became active when there is event occurs otherwise it goes to offline.
My hub firware has been updated to 46âŠ
Please find the device offline screenshot.
I canât think of what might be happening to make them disconnect.
Did you re-pair them with the hub on the new firmware?
Not yetâŠneed to check. Will try and get back to you with updated status.
That would be great. My other question is: For example the motion sensor from lidl has a driver, I was able to connect it and it works in the smart things app, but when I try it to link to google home, it doesnât recognize the device and does not link it. Do you know if it should work, or is it only working with SmartThings?
I donât know if all types of smartthings devices are exposed to Google home, I donât use it.
Other users may be able to help you with this.
Does Google home recognise virtual devices ?
If it does you can try creating a virtual device then set up a routine to switch on/off the virtual device when your physical device detects an event
Yes, Google Home recognizes at least some ST virtual devices. And if the device has switch capabilities you can use it to trigger Google Home routines.
