Thank you!
I know the solution of the virtual switches, I just try to avoid it as much as possible because it will cost me a lot of automations and will be cumbersome.
I hope there will be childs switches also for my multi switch soon
Thank you!
Iβve just tried this one but it has same result.
Battery is always 0 and status always closed. Nothing changes when I move reciever.
Well, I have no idea, if device really use clusters 0500 and 0001 it should work.
If you want to send some log with the CLI, Iβll take a look
This device is not going to work for you with luminance either.
You can search for other sensors that work well, like this one in the link, but hs and more if you search the thread
One more basic magnetic Door/Window switch. Similar one found driver, but there must be different fingerpring. [image] [Screenshot_20221115_201153_SmartThings] Thanks much.
I have a couple of these Sengled outlets on my property to support some appliances that I have. Would it be possible to add the fingerprints for this outlet to your Zigbee Switch MC pack? The signal strength indicator should help with some rearranging that I will need to undergo soon.
Hi Mariano,
Unfortunately the last character doesnβt show up in the Thing driver Any suggestions on how to find it in a different way?
Regards,
Erwin
You can see in App event history of device
Hi Mariano,
Yes itβs 6, correct. Just checked and the full Manufacturer is _TZ3210_K1msuvg6.
Regards,
Erwin
Hi @Mariano_Colmenarejo
I just found your collection of Edge drivers! They are awesome, thank you so much for your contribution.
Do you think is it possible to add a driver for ID Lock 150 smart lock:
Also, checking the Aqara Zigbee window treatment did not find the Aqara Roller Shade Driver E1. Would it be possible to add a fingerprint for this as well?
Hi,
All works⦠But a little error please refer to the following picture:
Can this be fixed ?
@nayelyz any ideas ?
I already added it with a 6, it should work
The tile does not interpret html text.
As the only capability that the profile has is signalMetrics, it shows the status in
html.
I donβt know if it can be fixed, Iβll look at it
Hi,
This device contain the EF00 Tuya cluster.
Did you find the way to deal with that cluster ?
I donβt know how to handle it and I already have enough to keep what I have published.
Only the one motion and light sensor uses the EF00 cluster because of Simon Tuckwell contribution, that he discover how works for this device with reverse-engineer .
- manufacturer: Datek
- model: ID Lock 150
- zigbeeNodeType: SLEEPY_END_DEVICE
Hi @kaveh_amouzgar
Added to this driver version.
I donβt know if it will work as I have no idea how locks work.
Surely the codes donβt work, try it.
Use it at your own risk
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Lock Mc
Version 2022-12-09T18:12:52.766664012
- id: "Datek/ID Lock 150"
deviceLabel: "Datek ID Lock 150"
manufacturer: Datek
model: ID Lock 150
deviceProfileName: base-lock
If you are looking for aqara window treatment you have to search with the fingerprints, not the brand model.
These are the Aqara models that are in my driver and the stock driver
{ mfr = "LUMI", model = "lumi.curtain" },
{ mfr = "LUMI", model = "lumi.curtain.v1" }
Please, if lock does not work tell me to remove from driver
@dotan_shai
Modified to show signal metrics text format in dashboard and detail-view
Name Zigbee Range Extender Mc
Version 2022-12-09T18:35:51.433700704
No change⦠still looks the same.
In details β OK
in dashboard β Text Problem.
Hi? Mariano!
Would it be possible to add Edge Drivers to this Dimmer Switch?
Larkkey Smart Zigbee Dimmer\Fan\Curtain switch
Thank you!
With new version?
